Hi, i was working on a toilet occupancy indicator that will detect the presence of people.
However, for some reason, the transmitter side, the Boolean is always stuck on the True side. Can anyone help to figure this out?
Transmitter
#include <RH_ASK.h>
#include <SPI.h> // Not actually used but needed to compile
RH_ASK driver;
boolean check=true;
int buttonState = 1;
const int buttonPin =2;
int PIR = 7;
pinMode(13, OUTPUT);
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH);
pinMode (PIR,INPUT);
Serial.begin(9600); // Debugging only
if (!driver.init())
Serial.println("init failed");
pinMode(PIR, INPUT);
digitalWrite(13, check);
buttonState = digitalRead(buttonPin);
int sense = digitalRead (PIR);
if (buttonState == HIGH){
check = false;}
else if (buttonState == LOW)
{if(check == true){;}
else if(sense == HIGH){check = true;}}
if( check == true ){
const char *msg = "a";
driver.send((uint8_t *)msg, strlen(msg));
driver.waitPacketSent();
Serial.print("a");
delay(100);
{const char *msg = "b";
Serial.print("b");
delay(100);}
Reciever
#include <RH_ASK.h>
#include <SPI.h> // Not actualy used but needed to compile
int led1 =2;
RH_ASK driver(2000,15,12,13,false);
int led2 =4;
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
if (!driver.init())
int i;
uint8_t buf[5];
uint8_t buflen = sizeof(buf);
if ( driver.recv(buf, &buflen) )
driver.printBuffer("Got:", buf, buflen);
Serial.println((char*)buf);
Serial.println(sizeof(buf));
{if(buf[0] == 'a')
{digitalWrite(led1, HIGH);}
else if(buf[0] == 'b')
{digitalWrite(led1, LOW);}
// lcd.setCursor(0, 0);
//lcd.print((char*)buf);
i++;
/*if(pos < 2)
lcd.setCursor(0, pos);
pos=0;
Serial.println("");
//lcd.clear();
for (i = 1; i < buflen; i++)
Serial.print((char)buf[i]);
pos++;
just normally attached without any resistor. But i don't see that as a problem as the base code i made beforehand
boolean check=true;
int PIR = 7;
check = false;}
the problem is that the boolean become stuck to true after i add the Radiohead code. But, i dont know if the button is the problem
The way you set out your brackets and things like that doesn't look tidy.
Anyway ..... what you could do is it strategically put some print statements (bread-crumb trails) in parts of your 'if' 'case' code....so you can visually see in the serial monitor screen which levels are reached.
almost1234:
The problem is that the boolean become stuck to true after i add the Radiohead code. But, i dont know if the button is the problem
Then simply (temporarily) go back to your 'previous' version of code, without the 'radiohead' code .... to see if your button works there.
UPDATE:
after trying some of your suggestion, i discovered that the button is not in fault here, but instead is the code itself.
After several try testing, i realized that the serial freezes when i pressed the button and the PIR sensor detected some movement. I saw that the boolean turns true for a second, but then the whole thing crashes instantly afterwards.
At this point, i could not find the reason behind this freeze as i tried to use every resistor in every possible place and it do not fix this problem.
Sorry for not including any updates regarding the code, here is it.
#include <RH_ASK.h>
#include <SPI.h>
RH_ASK driver;
boolean check=true;
int buttonState = 0;
int PIR =7;
digitalWrite(buttonPin, LOW);
int sense = digitalRead(PIR);
if (buttonState== LOW){check = false;}
else if (buttonState == HIGH){if (check == true){;}
else if (sense == HIGH){check = true;}}
Serial.println(sense);
if( check == true){
Serial.println("yay");}
I altered the setting so that the button with resistor can work, but the rest is still the same as per se.
I have attached the picture of the configuration and the freeze error that occured.
Thanks
A simple auto-reformat (ctrl-T) by the IDE makes this code a lot more readable:
#include <RH_ASK.h>
#include <SPI.h>
RH_ASK driver;
boolean check = true;
const int buttonPin = 2;
int PIR = 7;
pinMode (PIR, INPUT);
if (buttonState == LOW) {
check = false;
else if (buttonState == HIGH) {
if (check == true) {
else if (sense == HIGH) {
check = true;
if ( check == true) {
That's some oddly nested if/else statement set indeed. Are you sure this is what you want to do?
Reading the screenshot, it seems like your code freezes the moment sense becomes 1 aka HIGH. When this happens, and buttonPin is HIGH (button not pressed?), check is set to true and the last block of your loop() is entered:
So i tried to reworked with my code and try to make it clean as possible to try to reduce the error
#include <RH_ASK.h>
#include <SPI.h>
RH_ASK driver;
boolean recheck = true;
boolean buttonState = 1;
const int PIR = 7;
digitalWrite(buttonPin, HIGH); //put input to high and wait for button to pull it low
digitalWrite(13, recheck);
boolean sense = digitalRead(PIR); //shouldn't this be boolean?
recheck = false;
//this line seems redundant
// if (recheck == true) {}
recheck = true;
Serial.println(recheck);
if ( recheck == true) {
Serial.println("Sent message a");
delay(500); //slot in a short delay else it may give errors sometimes.
However, it still gives the same results as the root problem: the arduino still freezes when the button is pressed and the PIR sensor detect movement.
So I guess I have to agree to the fact regarding
wvmarle:
So my money is on the problem being related to whatever this "driver" is doing.
Even if it is true, what and why does it conflict and cause a halt to the arduino itself? it doesnt make sense
The library is RadioHead, just in case somebody asking.
More likely: it is just sitting there waiting for something that never happens.
Start by adding print statements in every line (just print 1, 2, 3, etc). Then you know at which line it hangs. Comment out that one line. See what happens. If it works, you know exactly at which point your code hangs. Then go and find out why. Start with the most suspected block:
