I want to have some standalone ATMega328P chips burned by a vendor with the LilyPad ATMega328P bootloader. I have used the USBTinyISP to burn some chips but I'm not sure which image in the Android Library I should supply to the vendor.
Thanks
Thanks
You'll need to send the fuse settings also.
Android library?
Look in this folder:
Arduino/hardware/arduino/avr/bootloaders/ pick a board type
Fuse settings from boards.txt file, find the section for the board you are using.That will also tell you the bootloader file name.
This info is incredibly helpful. Just to confirm, this is what I should send them:
lilypad.menu.cpu.atmega328.bootloader.low_fuses=0xFF
lilypad.menu.cpu.atmega328.bootloader.high_fuses=0xDA
lilypad.menu.cpu.atmega328.bootloader.extended_fuses=0x05
lilypad.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
based on the below from the boards.txt.
lilypad.name=LilyPad Arduino
lilypad.upload.tool=avrdude
lilypad.upload.protocol=arduino
lilypad.bootloader.tool=avrdude
lilypad.bootloader.unlock_bits=0x3F
lilypad.bootloader.lock_bits=0x0F
lilypad.build.f_cpu=8000000L
lilypad.build.board=AVR_LILYPAD
lilypad.build.core=arduino
lilypad.build.variant=standard
lilypad.menu.cpu.atmega328=ATmega328
lilypad.menu.cpu.atmega328.upload.maximum_size=30720
lilypad.menu.cpu.atmega328.upload.maximum_data_size=2048
lilypad.menu.cpu.atmega328.upload.speed=57600
lilypad.menu.cpu.atmega328.build.mcu=atmega328p
lilypad.menu.cpu.atmega168=ATmega168
lilypad.menu.cpu.atmega168.upload.maximum_size=14336
lilypad.menu.cpu.atmega168.upload.maximum_data_size=1024
lilypad.menu.cpu.atmega168.upload.speed=19200
lilypad.menu.cpu.atmega168.bootloader.low_fuses=0xe2
lilypad.menu.cpu.atmega168.bootloader.high_fuses=0xdd
lilypad.menu.cpu.atmega168.bootloader.extended_fuses=0x00
lilypad.menu.cpu.atmega168.bootloader.file=lilypad/LilyPadBOOT_168.hex
lilypad.menu.cpu.atmega168.build.mcu=atmega168
