Bootloader Uno to Uno, invalid device signature
Hello! I've had trouble uploading sketches to one of my Unos so I thought I'd try to burn a new bootlader to it from another functioning Uno, but this is also causing problems. I've tried connecting the two boards via the digital and power pins and using the ICSP header pins but I get an error both times. Anyone know how to fix this? I've checked all the cables are connected properly and have followed the instructions on the Arduino website carefully (correct port, Board: "Arduino Uno", Programmer: "Arduino as ISP", using example 11.ArduinoISP > ArduinoISP).
This is the error message:
Arduino: 1.8.19 (Windows 7), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
If it's useful the programmer board states "UNO" on the back so it might be an earlier generation. It is fully functional though. The target UNO is "UNO R3 'SMD edition".
If it's also useful, this is the error message I get when trying to upload sketches to the faulty Uno.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2A03_0043 -ide-version=10819 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_802863 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_500453 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2A03_0043 -ide-version=10819 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_802863 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_500453 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863\\sketch\\Blink.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863\\sketch\\Blink.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\User\AppData\Local\Temp\arduino_cache_500453\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863/Blink.ino.elf" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863\\sketch\\Blink.ino.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863/..\\arduino_cache_500453\\core\\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863/Blink.ino.elf" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863/Blink.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863/Blink.ino.elf" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863/Blink.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_802863/Blink.ino.elf"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM13 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\arduino_build_802863/Blink.ino.hex:i
         Using Port                    : COM13
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xdb
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Any help greatly appreciated, I don't want to throw away this board!
Is the board you want to programme powered?
Will it not be powered via the 5V pin on the programming board?
I cannot see your wiring. And did you check with a DMM?
They are wired together as per the instructions on this page. I've just tested the programming board and it is outputting 5 volts (5.18 to be precise)
Well, your messages from avrdude look exactly like there is no target connected. Therefore I suppose there is something wrong with the wiring ( Or your target UNO may be defective ).
Thanks. The wiring is totally fine so I suspect this is one Uno that's destined for the trash. Thanks for your help!
Yes, sometimes that's just the way it is ... :slightly_frowning_face:
