I have this Arduino UNO r3 with the ATmega 328 chip.
The L led is almost on constant, but the TX led keeps, blinking, flickering and goes off.
I have been searching, and it seems like need to burn a new bootloader to my ATmega chip.
I that possible from the arduino IDE or do I need a secondary arduino to do it?
I can only find some stand alone projects, which really, isnt that helpful.
That sounds like you have a sketch loaded onto the board that's outputting serial data and occasionally blinking the LED? Why do you suspect there is a problem?
Burning bootloader requires external hardware - either another Arduino, or a USBAsp ($2-3 shipped on ebay), or some other ISP programmer (the USBAsp is cheap and good - though there are a number of others)
Every one of the listed error, is from trying to upload that sketch:
First try:
´Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1.104 bytes (3%) of program storage space. Maximum is 32.256 bytes.
Global variables use 11 bytes (0%) of dynamic memory, leaving 2.037 bytes for local variables. Maximum is 2.048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfd
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfd
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfd
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfd
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfd
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfd
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfd
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfd
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfd
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfd
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Second try
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4b
avrdude: ser_send(): write error: sorry no info avail
third try
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x80
