Breadboard adapter/connector shield?
I've looked high and low, but cannot find this type of thing anywhere - does anyone know of one?
I love working with the Ardweeny and Aruduino Nano, which plug easily into a breadboard, providing access to all of the Arduino pins on the breadboard. Stand-alone Arduino circuits become very fragile once you have a dozen or so jumper wires bridging from the Arduino to the breadboard, and of course, one wire pulled loose wrecks the whole thing.
Does anyone make a simple shield that routes the Arduino pins through a ribbon connector or such, to a small/narrow PCB that would span the center slot of a breadboard, thus providing breadboard access to all of the pins? It wouldn't need to take up any more space on the board than a bare AVR chip, and could mimic the relative placement of the Arduino pins on the breadboard. (Heck, if the pins were labeled on the PCB, that'd be doubly awesome.) If built as an actual shield, then it could be stacked with other shields on the stand-alone Arduino.
Has anyone seen something like this?? I can't believe such a thing doesn't exist - I suspect I must have simply somehow missed it in my searching.
Thanks for any info!
You can buy ribbon cable and male-male headers and solder the ribbon cable to the headers and plug the headers into breadboard.
Just for the heck of it I looked at what I had lying around and found a breadboard that fits right between the stackable headers.
You mean like these ?
Sadly, the shields w/ the little built-in breadboards just don't provide enough real estate for many projects. I'm envisioning a very bare-bones shield that plugs into the Arduino, then has a multi-conductor cable (or several) that leads to a very simple PCB (or 2-3) which just distributes the incoming wires from the Arduino to pins that plug into the breadboard. The end would be as wide as a regular DIP, allowing access to the Arduino pins on the breadboard, but avoiding the rats nest of jumper wires between the Arduino and the breadboard.
At present, I mount the Arduino and the breadboard onto a slab of plexiglass, then run jumpers between them, which at least reduces the chances of wires pulling loose, but still, you end up with about twice as much wire as you need, and when something inevitably comes loose, its a serious pain to track down what it was, with all of the various wires running between the Arduino and the breadboard.
I guess perhaps such a thing doesn't exist - might be a good longer-term investment of time to make, but will just be a distraction from my current projects, at the moment. <:-)
If you contact Crossroads, he can make you a shield any size you want that will plug into the UNO and have wall to wall breadboard and shield headers to plug another shield into.
Thanks for the tip - I'll give him a holler!
I'm around, just unable to log in during the day at the moment.
Do you need something like this?
http://wwww.crossroadsfencing.com/BobuinoRev17/
He needs a stretch limo breadboard shield with headers on top and a LONG breadboard on top extending out both sides.
to accomodate a breadboard twice the length of one the size of the shield . (if I understood the OP correctly)
Sorry, wish I had more time, and I'd make a drawing. First, to be honest, this is just something I was kind of hoping existed, and someone could point me to where to buy it. I doubt its worth somebody working up a custom design for. But, since we're discussing it, I'll try to describe better what I had in mind.
The shield would be very basic - essentially a pass-through, but each of the pins would be routed to one (or maybe 2-3, total) ribbon connectors (or similar multi-conductor cabling). (Ideally, the reset button, on-board LEDs and ICSP would be replicated on the shield, as well...)
The ribbon cable(s) (connected to the board through the ribbon connector(s)) would then have a small DIP-spaced PCB on the other end - ideally in two rows of pins that can span the center divide of a breadboard, which could be inserted into the breadboard, thus providing access on the PCB to all of the Arduino pins. This allows you to get all of the pins to the breadboard by simply plugging in the small DIP-spaced PCBs, vs running a rats nest of jumper wires from the Arduino to the PCB.
This would not include a PCB itself - the idea is, you could plug the little adaptor gizmos into any breadboard of your choice - this simply provides the plumbing to get the signals from the Arduino to a breadboard.
On a smaller Arduino, the little DIP-spaced PCB (lets call it an 'adaptor') - the adaptor - could really just be a single item - an Uno, for instance, would just be a little 2x16 (or thereabouts) adaptor (ie, 2 rows of 16). The PCB could even be labeled with the pin names, so it'd be just like having the Uno on the breadboard.
For something like a Mega, you're now talking something along the lines of a 2x50 adaptor, which will eat up most of a typical breadboard just on its own (ie, no space for other components on the breadboard :slight_smile: So, maybe it would be broken out into 2-3 adaptors - one for power/reset/refs - one for analog/pwm - one for digital. These could then be plugged in as needed or not, or even plugged into separate PCBs, if needed. Again, the adaptors would be labeled with pins, so its just like having the Mega on the breadboard - no need for the rats nest between the Mega and the breadboard.
The closes thing I could find like this is the Adafruit 'Patch Shield' (Patch shield for Arduino [v5.01] : ID 256 : $19.50 : Adafruit Industries, Unique & fun DIY electronics and kits), but I'd dispense with the 'patching' part, and just route all the pins through cabling to adaptors on the other end, each with its individual function labeled. Heck, even a super-duper patch shield would work - it'd just be great to have the pins labeled on the adaptor end, and I personally see no need for the 'patching' part - just route them all. Breadboard space is cheap.
In reality, eating up breadboard real estate is much less of a concern than avoiding the huge mess of wires between the Arduino and the breadboard. Breadboards are cheap enough that you can easily buy more real estate, but you if have one odd jumper wire come loose between your Arduino and your breadboard, you're in for a world of pain before you first identify that as the problem, and second get the errant jumper wire(s) seated back in the right place. This shield/cable/adaptor approach would make that a problem of the past. (Maybe I'm just a klutz - combined w/ the fact that most of my projects involve interaction with real-world things, in places where things get moved around, shaken, etc during development and testing - but something solid like this would make my life much easier!)
Dos that better clarify what I was describing poorly?
Like this?
http://www.inmojo.com/store/liudr-arduino-and-physics-gadgets/item/phi-connect-arduino-cable-management/
HOLY COW - YES!! That's exactly what I had in mind!!
Sadly, I need one for the Mega board, but I may well buy one of those, simply because its so great to actually see somebody built one! :slight_smile: (and I still play around w/ the Uno sometimes)
Sure would be great if they made something like that for the Mega!
I thought about making one for mega but there are too many pins. Two 40-pin ribbon cable won't be enough.
