Breaking out the Breakout
Adding back-to-back 2.54mm screw terminals to the Portenta Breakout Board
I discovered a little trick. You can extend and straighten the pins in the 2.54mm spaced pins of a screw terminal block. Then you can put them back to back. Use needlenose pliers to straighten them. A little vice can help a tiny bit getting things started. Put them in in groups, and twist them down a tiny bit with the pliers (Orange circle is before, Purple circle is after):
Suggest you cross-post this in the hardware section, where there's a long list of such nice hacks.
Cross-posted
NO.....
Suggest to the moderator that the thread be moved.
Cross posting encourages two different threads for the same project.
Tom... :smiley: :+1: :coffee: :australia:
I removed it. Looks like it's in the Hardware list anyway.
