Hi everyone, I'm having trouble broadcasting strings between two Arduino Uno units each equipped with an XBee-Pro S2C radio.
Background
I am attempting to build a system that relays lap times and messages from a laptop to remote display units installed on 4 go-karts. The program should send a laptime as a string to the Arduino via USB cable serial connection, which then broadcasts the unchanged string through the XBee software serial connection.
Based on my research it is my understanding that the XBee broadcast-to-all function should suit my needs. My intention is to have 1 coordinator connected to a laptop, broadcasting to multiple end devices. Currently I am working on a proof-of-concept with one transmitter and one receiver. I should be able to enter a 6-character string beginning with 'A' into the Java program, and the receiving units should all update their screens to show the last 4 characters of the string. However, this has not occurred.
The laptop runs a Java program that obtains lap times and user input messages and outputs them to an XBee unit. From what I could gather, the use of a USB XBee Explorer (in my case, Sparkfun P/N: WRL-11812) necessitates the use of the RXTXSerial DLL which would prevent the software from being packaged wholly in an executable JAR file, so I decided to send serial data to an Arduino with an XBee in AT mode configured as a coordinator which allows me to use the Java-Arduino Communication Library.
I strongly suspect this is an XBee config or data interpretation issue, but just in case, the full setup info is included below along with my work done:
Hardware
Transmitter (Coordinator)
1 x Arduino Uno
1 x Seeed Studio XBee Shield V2.0 (Tx/Rx jumpers set to pins 2 and 3 respectively)
1 x XBee-Pro S2C ZigBee (P/N: XBP24CZ7SITB003)
1 x Arduino USB cable (to laptop)
Receiver (Router)
1 x Arduino Uno
1 x XBee-Pro S2C ZigBee (P/N: XBP24CZ7WITB003)
1 x Generic 128x64 Monochrome OLED Display (Compatible with Adafruit SSD_1306 library)
Software
Transmitter Arduino Code
#include <SoftwareSerial.h>
SoftwareSerial XBee(2,3);
while(!Serial){
XBee.begin(9600);
XBee.write("AMBOOT");
while(Serial.available()){
XBee.print(Serial.readString());
Receiver Arduino Code
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <SPI.h>
#include <Wire.h>
SoftwareSerial XBee(2,3); // RX,TX
// If using software SPI (the default case):
#define OLED_MOSI 11
#define OLED_CLK 12
#define OLED_DC 9
#define OLED_CS 8
#define OLED_RESET 10
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
/* Uncomment this block to use hardware SPI
#define OLED_DC 6
#define OLED_CS 7
#define OLED_RESET 8
Adafruit_SSD1306 display(OLED_DC, OLED_RESET, OLED_CS);
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH 16
static const unsigned char PROGMEM bmp[] =
//bitmap code omitted
#define SSD1306_LCDHEIGHT 64
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
int clap = 1;
String clapt = "1";
String indata = "MTRACE";
String ddata = "RACE";
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
display.begin(SSD1306_SWITCHCAPVCC);
display.clearDisplay();
display.drawBitmap(0,0, bmp, 128,64, WHITE);
display.display();
delay(4000);
XBee.begin(9600);
//XBee.write("n");
//Code to display startup message omitted
XBee.begin(9600);
XBee.setTimeout(6000);
while (XBee.available())
indata = XBee.readString();
if (indata.charAt(0)== 'M' or indata.charAt(0) == 'A'){
if (indata.charAt(1)== 'T'){
clap++;
clapt = clap;
//Code to display lap count omitted
indata.remove(0,2);
ddata = indata;
//code to display lap time omitted
XBee Configuration
Transmitter
Firmware Ver: 4060
Coordinator: Enabled
DH: 0
DL: FFFF
Receiver
Firmware Ver: 4060
Coordinator: Disabled
DH: 0
DL: 0
(to be continued below)
