Hi Guys,
I'm trying to connect a 8 channel relais module (active low) to my arduino but i can't get it to work. I think i tried litterly everything but i want to check with you guys. Am i missing something, or is my (new) part just broken).
I dit:
Arduino Uno (powered via PC/USB)
8 chanel 5v relay board
External 5v power supply connected to JD-VCC and GND of the relay board
Arduino pin 1 t/m 8 connected to board IN 1 t/m 8
Arduino on a basic testcode:
pinmode(1, OUTPUT)
digitalwrite(1, LOW)
I cant get any of the relays to switch in any way. What am i missing???
With an external supply you need to remove the JD-Vcc jumper, and put the Arduino 5V onto Vcc, else there's no circuit for the led in the opto isolator.
edit: see circuit diagram here at yourduino.
You also shouldn't use pin 1 (or 0) for everyday IO.
thanks for your help
I removed the jumper. The VCC pin between the JD-VCC and GND is empty now.
i connected the VCC next to the IN pins to the 5v from arduino. Still no result
I also tried to connect the arduino 5v to the VCC between de JD-VCC and GND. Also no result.
Sounds right but let's see the whole Arduino code, and a drawing of your connections maybe?
Have you got the gnd of the relay board connected to the gnd of the Arduino?
Thanks.. Tom..
TomGeorge:
Didn't seem like it, and with that board he shouldn't, since the Arduino only needs to give Vcc and a low data pin to activate the led in the opto. (Not sure of you were asking because you think he should or shouldn't have a common ground.)
Just that when you look at the input pins as well as a Vcc there is a GND pin.
I agree that pull down active shouldn't need a gnd.
Tom...
Are you connected like this?
Graphic by @dlloyd.
BTW, don't use pin 1, it's the serial TX pin, and the relays are energized when the output pin is driven LOW.
Santepeter85:
... I'm trying to connect a 8 channel relais module (active low) to my arduino but i can't get it to work. I think i tried litterly everything but i want to check with you guys. Am i missing something, or is my (new) part just broken)...
The easiest way to test these boards is to not use any Arduino at all.
Get a 5v power supply, and first check that it is putting out 5 volts.
Then connect it properly to VCC and ground of the relay board, and (with the power jumper on) then take another (+) wire and try touching all the relay input pins one at a time. This should flip the relays on/off. If it doesn't, then something is wrong with the board.
Doug384:
Correction:"then take another" (-) not + "wire and try touching all the relay input pins one at a time." electricity only flows negative to positive. Not positive to positive.
