Hello everyone, I am trying to get a brushless motor (ripped off a rc plane with a 18a arrowind esc) to be controlled by my arduino. Only issue is it will not turn! I am trying to run the code below (copied of of the forums here too XD)
I am using an arduino uno, with the ground pin and input (to pin 7) of the esc attached. I am using an external lipo battery.
When I start everything the esc beeps once and then does nothing.
// this uses the Arduino servo library included with version 0012
// caution, this code sweeps the motor up to maximum speed !
// make sure the motor is mounted securily before running.
#include <Servo.h>
Servo myservo;
void arm(){
// arm the speed controller, modify as necessary for your ESC
setSpeed(0);
delay(1000); //delay 1 second, some speed controllers may need longer
void setSpeed(int speed){
// speed is from 0 to 100 where 0 is off and 100 is maximum speed
//the following maps speed values of 0-100 to angles from 0-180,
// some speed controllers may need different values, see the ESC instructions
int angle = map(speed, 0, 100, 0, 180);
myservo.write(angle);
myservo.attach(9);
arm();
int speed;
// sweep up from 0 to to maximum speed in 20 seconds
for(speed = 0; speed <= 100; speed += 5) {
setSpeed(speed);
// sweep back down to 0 speed.
for(speed = 95; speed > 0; speed -= 5) {
setSpeed(speed);
setSpeed(0);
delay(5000); // stop the motor for 5 seconds
Thanks for the help!
