I am using BLExAR along with a BT05 Bluetooth module and I am trying to send a message to an 8 x 32 LED matrix. I can connect to the BT05 but nothing appears on the LED matrix. Here is the sketch I am using, am I missing something or do I need to enter anything else before or after my message? Any help would be much appreciated.
# File Name: MikroMatrix
# Board: Arduino UNO
# Programming Language: C & C++ / Arduino IDE
# Objective: Scrolling LED dot Matrix & Seven Segment
# Operation: Scrolls a message over a LED dot matrix Change its scrolling speed
intensity and message text during scroll
# Author: MUHAMMAD KASHIF
# Date: December 14, 2020
# Place: Lahore - Pakistan
This code is a public example.
#include <SoftwareSerial.h>
#include <MikroMatrix.h> // download library from https://github.com/Kashif2812/MikroMatrix
#include <TimerOne.h> // include timer library for software interrupt
#define CLOCK_PIN 13 // CLK pin of MAX7219 module on arduino UNO Pin no 13
#define CHIP_SELECT 10 // CHIP_SELECT of MAX7219 module on arduino UNO Pin no 10
#define DATA_PIN 11 // DATA_PIN pin of MAX7219 module on arduino UNO Pin no 11
#define NUM_OF_DEVICES 4 // change this variable to set how many MAX7219's you'll use
#define RX 0 // connect arduino pin no 0 to HM10's TX pin
#define TX 1 // connect arduino pin no 1 to HM10's RX pin
char message[100];
SoftwareSerial BT05(RX, TX); //RX|TX
//MAX_7219 class for LED_Matrix and Seven Segment driver:
MAX_7219 MAX_7219_MODULE(DATA_PIN, CHIP_SELECT, CLOCK_PIN, NUM_OF_DEVICES );
//MikroMatrixapp class for Seven Segment applications
MikroMatrixapp Matrix(&MAX_7219_MODULE);
BT05.begin(9600); // begin serial and set buad rate
MAX_7219_MODULE.init(); // initializing hardware
Timer1.initialize(200000); // initialize timer with 200 milli seconds
Timer1.attachInterrupt(call_back); // attach interupt with call back function
void call_back() // This is a function called during interruption
int brightness; // variable to hold the value of brightness
int Speed; // variable to hold the value of speed
if (BT05.available()) // condition to check if any value avail on seril buffer
char C=BT05.read(); // read identifier character
if (C=='B') // check that if identifier character is equal to "B"
brightness=BT05.parseInt(); // then incoming value will be equal to brightness
MAX_7219_MODULE.set_intensity(brightness); // write the value of brightness in brightness register
if (C=='S') // check that if identifier character is equal to "S"
Speed=BT05.parseInt(); // then incoming value will be equal to Speed
MAX_7219_MODULE.set_speed(Speed); // write the value of Speed in speed setting function
// note: For message identifier, use that character you are not using in your message
if (C=='t') // check that if identifier character is equal to "t"
memset(message , 0 , 100); // function to clear message array for new message
BT05.readBytesUntil('\r' , message , 100); // function to recive new message from Serial and store in message array
Matrix. scroll_left(message);
This guy is actually referring to the BT05, which is indeed a BLE device. I understand it is a bastardised CC2541 and looks identical, but maybe best avoided.
And well you might but, on the Internet, innocence can be quite shortlived, and the clown from Lahore hasn't a clue. He clearly states that he is using a Uno, but then declares software serial on the hardware serial pins 0,1 - a certain recipe for disaster and a clear indication of the author's competence.
I have no idea of what you are really trying to do, but you may find that this is actually your only problem (!), and you have two options:
Move Bluetooth and software serial to another pair of pins. I believe any pair of pins are OK for software serial on a Uno, except pins 0,1!
Leave Bluetooth where it is and delete all reference to software serial, i.e change "BT05" to simply "Serial". No need to define the pins, Arduino already knows that.
I would suggest the latter, but disconnect Bluetooth while uploading the code.
Thanks for your replies guys, I haven't done much with bluetooth to date. All I was trying to do was to use the terminal of the app to send a message to the LED Matrix which would then scroll across. I will try your suggestions Nick and see how it goes.
To be fair to the author, he had pins 1 & 2 in one file and pins 4 & 5 in another. It ws a message from someone else who stated it must be pins 0 & 1.
I have tried both of your options with no joy! I have discovered that my Bluetooth module is an HM-10 and can connect my phone to it no problem. when I send to it, I can see the led flashing but I have tried to write to the serial port but nothing appears. I did use a Serial.begin so it looks like something else is amiss.
#define CHIP_SELECT 3 // CHIP_SELECT of MAX7219 module on arduino UNO Pin no 10
#define RX 6 // connect arduino pin no 0 to HM10's TX pin
#define TX 7 // connect arduino pin no 1 to HM10's RX pin
char message[100];
Serial.begin(9600); // Added
Serial.println(brightness); //added
Serial.println(Speed); //added
Serial.println(message); //added
Matrix.scroll_left(message);
Connections are as follows:
LED Matrix
Data Pin - Pin 11
CS Pin - Pin 3
CLK Pin - Pin 13
HM10 - Bluetooth Module
TX Pin - Pin 6
RX Pin - Pin 7
GND - GND
VCC - 5V
I did try just using Serial.begin and dropping the SoftwareSerial but to no avail. I put the serial.println lines in to see if it would show up on the serial monitor, but nothing appears.
You were previously warned about having all the software serial reading within an interrupt context.
I would recraft the program without the timer interrupt, eliminate the callback, and just place that block of code in loop().
//#include <TimerOne.h> // include timer library for software interrupt
char message[100];
//Timer1.initialize(200000); // initialize timer with 200 milli seconds
//Timer1.attachInterrupt(call_back); // attach interupt with call back function
// void call_back() // This is a function called during interruption
//int brightness; // variable to hold the value of brightness
//int Speed; // variable to hold the value of speed
char C = BT05.read(); // read identifier character
if (C == 'B') // check that if identifier character is equal to "B"
brightness = BT05.parseInt(); // then incoming value will be equal to brightness
if (C == 'S') // check that if identifier character is equal to "S"
Speed = BT05.parseInt(); // then incoming value will be equal to Speed
if (C == 't') // check that if identifier character is equal to "t"
Serial also uses interrupts. Interrupts are disabled in the ISR.
Here is a demonstration code using the receive with end marker example from the serial input basics tutorial along with the strtok function to parse the data. For testing enter data from the serial monitor. This is just do demo the use of the serial input basics methods. Use what you want.
const byte NUM_CHARS = 110; // message length + 10
char receivedChars[NUM_CHARS]; // an array to store the received data
boolean newData = false;
char message[100];
Serial.println("<Arduino is ready> single letter command separated, with a COMMA");
Serial.println(" from an integer or a string. Like t,HelloWorld or S,60");
Serial.println("make sure that the sender terminates the data with a newLine (\\n)");
Serial.println('\n');
checkSerial();
//Matrix.scroll_left(message);
void checkSerial()
recvWithEndMarker();
//showNewData();
if (newData)
parseData();
void recvWithEndMarker()
static byte ndx = 0;
char endMarker = '\n';
char rc;
// REPLACE THE Serial in the next 2 lines with BT05 to use
// your software serial.
while (Serial.available() > 0 && newData == false)
rc = Serial.read();
//Serial.println(rc);
if (rc == '\r') // ignore carruage return
return;
if (rc != endMarker)
receivedChars[ndx] = rc;
ndx++;
if (ndx >= NUM_CHARS)
ndx = NUM_CHARS - 1;
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewData()
if (newData == true)
Serial.print("This just in ... ");
Serial.println(receivedChars);
//newData = false;
void parseData()
char *strings[3]; // an array of pointers to the pieces of the above array after strtok()
char *ptr = NULL;
byte index = 0;
ptr = strtok(receivedChars, ","); // delimiters, comma
while (ptr != NULL)
strings[index] = ptr;
index++;
ptr = strtok(NULL, ","); // delimiters, comma
//Serial.println(index);
// print all the parts
Serial.println("The Pieces separated by strtok()");
for (int n = 0; n < index; n++)
Serial.print("piece ");
Serial.print(n);
Serial.print(" = ");
Serial.println(strings[n]);
// convert string data to numbers
char command = char(*strings[0]);
if (command == 'B') // brightness
int brightness = atoi(strings[1]); // *** is this the appropriate data type?
//MAX_7219_MODULE.set_intensity(brightness); // **** commented for testing ****
Serial.print("\nSet brightness to ");
else if (command == 'S') // speed
int Speed = atoi(strings[1]); // *** is this the appropriate data type?
//MAX_7219_MODULE.set_speed(Speed); // **** commented for testing ****
Serial.print("\nSet speed to ");
else if (command == 't')
strcpy(message, strings[1]);
Serial.print("\nNew message is >> ");
Serial.println("******* invalid input *******");
Serial.print("command = ");
Serial.print(command);
Serial.print(" strings[1] = ");
Serial.print(strings[1]);
Serial.println(); // blank line
newData = false;
The HM-10 is a Bluetooth Low Energy (BLE) device. BLE works in a quite different way of BT (take a look at https://www.arduino.cc/en/Reference/ArduinoBLE) and it´s also more complicated.
BLExAR will find your module, but your code has to be completely different in order to exchange information.
The iphone app knows how to communicate with the HM10 (likely using some ble uart protocol) and the HM10 can communicate with the Arduino with serial or software serial.
Many thanks for your efforts, tried doing as you suggested no joy, then copy and pasted your code, again no joy. In the light of Brazilino's comment, it may be back to the drawing board.
groundFungus,
Many thanks for your efforts, I don't understand all of the code you posted but I will play about with it in the hope of learning something.
Brazilian,
Thank you for the information, I will investigate further. Is it possible to get a BT module that will work with my iPhone and a terminal app?
I appreciate all your replies, and apologise for wasting your time as it appears that it cannot work with that code.
I didn´t know the application creates some sort of ble uart protocol in an user transparent way.
@SierraGolfMike, take a look in this example that was given in #17 post. It has a code and may help you.
Unfortunately my experience trying to use Bluetooth and BLE with IOS let me with some traumas so, I don´t have an answer for your question regarding your IPhone.
