I currently have two motors connected via aL298N motor driver for the "head".
Left and right. Tilt up and down. That code is working and i can controller the motors with the PS4 controller on the right stick.
I need to connect two more motors via two BTS7960 that i want to control on the left stick.
this is the code that I am busy with:
#include <Bluepad32.h>
#include <BTS7960.h>
//PIN CONNECTIONS L298N
int ledPin = 2;
int ENApin = 14; //motor1 speed
int IN1pin = 27; //motor1 dir1
int IN2pin = 26; //motor1 dir2
int IN3pin = 25; //motor2 dir1
int IN4pin = 33; //motor2 dir2
int ENBpin = 32; //motor2 speed
//BYS7960 Board
#define L_EN 19
#define R_EN 21
#define L_PWM 22 //pin 5 supports 980hz pwm frequency
#define R_PWM 23 //pin 5 supports 980hz pwm frequency
BTS7960 motor1(L_EN, R_EN, L_PWM, R_PWM); //This method will create a object of the class BTS7960
ControllerPtr myControllers[BP32_MAX_GAMEPADS];
// This callback gets called any time a new gamepad is connected.
// Up to 4 gamepads can be connected at the same time.
void onConnectedController(ControllerPtr ctl) {
bool foundEmptySlot = false;
for (int i = 0; i < BP32_MAX_GAMEPADS; i++) {
if (myControllers[i] == nullptr) {
Serial.printf("CALLBACK: Controller is connected, index=%d\n", i);
// Additionally, you can get certain gamepad properties like:
// Model, VID, PID, BTAddr, flags, etc.
ControllerProperties properties = ctl->getProperties();
Serial.printf("Controller model: %s, VID=0x%04x, PID=0x%04x\n", ctl->getModelName().c_str(), properties.vendor_id,
properties.product_id);
myControllers[i] = ctl;
foundEmptySlot = true;
if (!foundEmptySlot) {
Serial.println("CALLBACK: Controller connected, but could not found empty slot");
void onDisconnectedController(ControllerPtr ctl) {
bool foundController = false;
if (myControllers[i] == ctl) {
Serial.printf("CALLBACK: Controller disconnected from index=%d\n", i);
myControllers[i] = nullptr;
foundController = true;
if (!foundController) {
Serial.println("CALLBACK: Controller disconnected, but not found in myControllers");
void dumpGamepad(ControllerPtr ctl) {
Serial.printf(
"idx=%d, dpad: 0x%02x, buttons: 0x%04x, axis L: %4d, %4d, axis R: %4d, %4d, brake: %4d, throttle: %4d, "
"misc: 0x%02x, gyro x:%6d y:%6d z:%6d, accel x:%6d y:%6d z:%6d\n",
ctl->index(), // Controller Index
ctl->dpad(), // D-pad
ctl->buttons(), // bitmask of pressed buttons
ctl->axisX(), // (-511 - 512) left X Axis
ctl->axisY(), // (-511 - 512) left Y axis
ctl->axisRX(), // (-511 - 512) right X axis
ctl->axisRY(), // (-511 - 512) right Y axis
ctl->brake(), // (0 - 1023): brake button
ctl->throttle(), // (0 - 1023): throttle (AKA gas) button
ctl->miscButtons(), // bitmask of pressed "misc" buttons
ctl->gyroX(), // Gyro X
ctl->gyroY(), // Gyro Y
ctl->gyroZ(), // Gyro Z
ctl->accelX(), // Accelerometer X
ctl->accelY(), // Accelerometer Y
ctl->accelZ() // Accelerometer Z
void dumpMouse(ControllerPtr ctl) {
Serial.printf("idx=%d, buttons: 0x%04x, scrollWheel=0x%04x, delta X: %4d, delta Y: %4d\n",
ctl->scrollWheel(), // Scroll Wheel
ctl->deltaX(), // (-511 - 512) left X Axis
ctl->deltaY() // (-511 - 512) left Y axis
void dumpKeyboard(ControllerPtr ctl) {
static const char* key_names[] = {
// clang-format off
// To avoid having too much noise in this file, only a few keys are mapped to strings.
// Starts with "A", which is offset 4.
"A", "B", "C", "D", "E", "F", "G", "H", "I", "J", "K", "L", "M", "N", "O", "P", "Q", "R", "S", "T", "U", "V",
"W", "X", "Y", "Z", "1", "2", "3", "4", "5", "6", "7", "8", "9", "0",
// Special keys
"Enter", "Escape", "Backspace", "Tab", "Spacebar", "Underscore", "Equal", "OpenBracket", "CloseBracket",
"Backslash", "Tilde", "SemiColon", "Quote", "GraveAccent", "Comma", "Dot", "Slash", "CapsLock",
// Function keys
"F1", "F2", "F3", "F4", "F5", "F6", "F7", "F8", "F9", "F10", "F11", "F12",
// Cursors and others
"PrintScreen", "ScrollLock", "Pause", "Insert", "Home", "PageUp", "Delete", "End", "PageDown",
"RightArrow", "LeftArrow", "DownArrow", "UpArrow",
// clang-format on
static const char* modifier_names[] = {
// clang-format off
// From 0xe0 to 0xe7
"Left Control", "Left Shift", "Left Alt", "Left Meta",
"Right Control", "Right Shift", "Right Alt", "Right Meta",
// clang-format on
Serial.printf("idx=%d, Pressed keys: ", ctl->index());
for (int key = Keyboard_A; key <= Keyboard_UpArrow; key++) {
if (ctl->isKeyPressed(static_cast<KeyboardKey>(key))) {
const char* keyName = key_names[key-4];
Serial.printf("%s,", keyName);
for (int key = Keyboard_LeftControl; key <= Keyboard_RightMeta; key++) {
const char* keyName = modifier_names[key-0xe0];
Console.printf("\n");
void dumpBalanceBoard(ControllerPtr ctl) {
Serial.printf("idx=%d, TL=%u, TR=%u, BL=%u, BR=%u, temperature=%d\n",
ctl->topLeft(), // top-left scale
ctl->topRight(), // top-right scale
ctl->bottomLeft(), // bottom-left scale
ctl->bottomRight(), // bottom-right scale
ctl->temperature() // temperature: used to adjust the scale value's precision
void processGamepad(ControllerPtr ctl) {
// There are different ways to query whether a button is pressed.
// By query each button individually:
// a(), b(), x(), y(), l1(), etc...
// PS4 X Button
//if (ctl->buttons() == 0x0001) {
// digitalWrite(ledPin, HIGH);
//if (ctl->buttons() != 0x0001) {
// digitalWrite(ledPin, LOW);
// LEFT JOYSTICK UP
if (ctl->axisRY() <= -25) {
int motor1 = map(ctl->axisY(), 25, 512, 50, 225);
digitalWrite(L_EN, HIGH);
digitalWrite(R_EN, HIGH);
analogWrite(L_PWM, motor1);
//int motor1.pwm = map(ctl->axisY(), -25, -508, 0, 255);
// motor1.pwm = i; //Set the speed, by default the speed is set to 255 you can change it
// motor1.front(); //front functions should turn the motor in clockwise direction
// RIGHT JOYSTICK UP
int motorSpeed = map(ctl->axisRY(), -25, -508, 50, 225);
digitalWrite(IN1pin, HIGH);
digitalWrite(IN2pin, LOW);
analogWrite(ENApin, motorSpeed);
// RIGHT JOYSTICK DOWN
if (ctl->axisRY() >= 25) {
int motorSpeed = map(ctl->axisRY(), 25, 512, 50, 225);
digitalWrite(IN1pin, LOW);
digitalWrite(IN2pin, HIGH);
// RIGHT JOYSTICK LEFT
if (ctl->axisRX() <= -25) {
int motorSpeed = map(ctl->axisRX(), -25, -508, 50, 225);
digitalWrite(IN3pin, HIGH);
digitalWrite(IN4pin, LOW);
analogWrite(ENBpin, motorSpeed);
// RIGHT JOYSTICK RIGHT
if (ctl->axisRX() >= 25) {
int motorSpeed = map(ctl->axisRX(), 25, 512, 50, 225);
digitalWrite(IN3pin, LOW);
digitalWrite(IN4pin, HIGH);
//RIGHT JOYSTICK DEADZONE
if (ctl->axisRY() > -25 && ctl->axisRY() < 25 && ctl->axisRX() > -25 && ctl->axisRX() < 25) {
analogWrite(ENApin, 0);
analogWrite(ENBpin, 0);
//LEFT JOYSTICK DEADZONE
if (ctl->axisY() > -25 && ctl->axisY() < 25 && ctl->axisX() > -25 && ctl->axisX() < 25) {
digitalWrite(L_EN, LOW);
digitalWrite(R_EN, LOW);
//analogWrite(ENApin, 0);
//analogWrite(ENBpin, 0);
if (ctl->a()) {
static int colorIdx = 0;
// Some gamepads like DS4 and DualSense support changing the color LED.
// It is possible to change it by calling:
switch (colorIdx % 3) {
case 0:
// Red
ctl->setColorLED(255, 0, 0);
case 1:
// Green
ctl->setColorLED(0, 255, 0);
case 2:
// Blue
ctl->setColorLED(0, 0, 255);
colorIdx++;
if (ctl->b()) {
// Turn on the 4 LED. Each bit represents one LED.
static int led = 0;
led++;
// Some gamepads like the DS3, DualSense, Nintendo Wii, Nintendo Switch
// support changing the "Player LEDs": those 4 LEDs that usually indicate
// the "gamepad seat".
// It is possible to change them by calling:
ctl->setPlayerLEDs(led & 0x0f);
if (ctl->x()) {
// Some gamepads like DS3, DS4, DualSense, Switch, Xbox One S, Stadia support rumble.
// It is possible to set it by calling:
// Some controllers have two motors: "strong motor", "weak motor".
// It is possible to control them independently.
ctl->playDualRumble(0 /* delayedStartMs */, 250 /* durationMs */, 0x80 /* weakMagnitude */,
0x40 /* strongMagnitude */);
// Another way to query controller data is by getting the buttons() function.
// See how the different "dump*" functions dump the Controller info.
dumpGamepad(ctl);
//void processMouse(ControllerPtr ctl) {
// This is just an example.
// if (ctl->scrollWheel() > 0) {
// Do Something
//} else if (ctl->scrollWheel() < 0) {
// Do something else
// See "dumpMouse" for possible things to query.
// dumpMouse(ctl);
//void processKeyboard(ControllerPtr ctl) {
// if (!ctl->isAnyKeyPressed())
// return;
//if (ctl->isKeyPressed(Keyboard_A)) {
// Do Something
// Serial.println("Key 'A' pressed");
// Don't do "else" here.
// Multiple keys can be pressed at the same time.
//if (ctl->isKeyPressed(Keyboard_LeftShift)) {
//Serial.println("Key 'LEFT SHIFT' pressed");
//if (ctl->isKeyPressed(Keyboard_LeftArrow)) {
//Serial.println("Key 'Left Arrow' pressed");
// See "dumpKeyboard" for possible things to query.
//dumpKeyboard(ctl);
//void processBalanceBoard(ControllerPtr ctl) {
// if (ctl->topLeft() > 10000) {
// Do Something
// See "dumpBalanceBoard" for possible things to query.
//dumpBalanceBoard(ctl);
void processControllers() {
for (auto myController : myControllers) {
if (myController && myController->isConnected() && myController->hasData()) {
if (myController->isGamepad()) {
processGamepad(myController);
else {
Serial.println("Unsupported controller");
// Arduino setup function. Runs in CPU 1
//L298N OUTPUT
pinMode(ledPin, OUTPUT);
pinMode(IN1pin, OUTPUT);
pinMode(IN2pin, OUTPUT);
pinMode(ENApin, OUTPUT);
pinMode(IN3pin, OUTPUT);
pinMode(IN4pin, OUTPUT);
pinMode(ENBpin, OUTPUT);
//BTS7960 OUTPUT
pinMode(L_EN, OUTPUT);
pinMode(R_EN, OUTPUT);
pinMode(L_PWM, OUTPUT);
pinMode(R_PWM, OUTPUT);
//motor1.begin(); //This method will set the motor driver pins as output
// motor1.Enable(); //This method will set the L_EN and R_EN to HIGH or digitalWrite them to +5v/3v depending on your mcu
Serial.printf("Firmware: %s\n", BP32.firmwareVersion());
const uint8_t* addr = BP32.localBdAddress();
Serial.printf("BD Addr: %2X:%2X:%2X:%2X:%2X:%2X\n", addr[0], addr[1], addr[2], addr[3], addr[4], addr[5]);
// Setup the Bluepad32 callbacks
BP32.setup(&onConnectedController, &onDisconnectedController);
// "forgetBluetoothKeys()" should be called when the user performs
// a "device factory reset", or similar.
// Calling "forgetBluetoothKeys" in setup() just as an example.
// Forgetting Bluetooth keys prevents "paired" gamepads to reconnect.
// But it might also fix some connection / re-connection issues.
BP32.forgetBluetoothKeys();
// Enables mouse / touchpad support for gamepads that support them.
// When enabled, controllers like DualSense and DualShock4 generate two connected devices:
// - First one: the gamepad
// - Second one, which is a "virtual device", is a mouse.
// By default, it is disabled.
BP32.enableVirtualDevice(false);
// Arduino loop function. Runs in CPU 1.
// This call fetches all the controllers' data.
// Call this function in your main loop.
bool dataUpdated = BP32.update();
if (dataUpdated)
processControllers();
// The main loop must have some kind of "yield to lower priority task" event.
// Otherwise, the watchdog will get triggered.
// If your main loop doesn't have one, just add a simple `vTaskDelay(1)`.
// Detailed info here:
// https://stackoverflow.com/questions/66278271/task-watchdog-got-triggered-the-tasks-did-not-reset-the-watchdog-in-time
// vTaskDelay(1);
delay(150);
