Buck boost converter
Hello, im trying to build a buck boost converter based of the classick buck converter circuit with the arduino providing the switching frequency.
In my case i am using the arduino nano to generate a switching frequency of 50khz, although i have reached up to 100khz so that is an option aswell.
The buck converter works, converting 12v to 60v however as soon as a load is applied to the output of the buck boost comverter, the voltage drops down to around 35v!
Can anyone with some knowledge of buck converters explain to my why this is caused? Is there a solution to increase the maximum possible load?
A few things i have thought of
  • diode losses
    (such a large loss seems a bit extreme for this?)
  • bad power mosfet? Tried changing to a few others, still getting voltage drops
  • duty cycle? Tried changing it around, less duty cycle draws less idle current, higher percentage duty cycle draws more idle current, mosfet is hotter.
Many SMPS are using ~1Mhz
Suggest you use a ready made board, much cheaper and easy to use as a daughter card.
"The buck converter works, converting 12v to 60v " Hint: A buck converter bucks the voltage down to something less than its input. A boost converter does the opposite it boosts the voltage above its input voltage. A SEPIC converter is a combination of both a buck and boost so it will control the output voltage anywhere within its input range, above or below the input voltage. Your current on the input will be the ratio of the voltage plus the inefficiencies. So a boost with a load of 1A at 50V from a 10V supply will require 5A+ at the input.
You didn't say what the load current is but as gilshultz says, the energy has to come from the input side and if you are boosting the voltage, you need more current into the boost circuit.
i.e. You are boosting voltage and cutting current...
Low voltage in and higher voltage out.
High current in and lower current out.
In buck mode it works the opposite and you can get more current-out than you feed-in (at lower voltage out).
That's only true for switchmode regulators. A linear regulator only steps-down and you can't get more current-out than you feed-in. Linear regulators are not as efficient and they tend to get hot (or hotter).
Power (wattage) = Voltage X Current.
And the energy has to be stored in the inductor and capacitor.
Normally, the duty cycle is controlled by feedback to maintain/control the voltage.
+ 1 that
This shows the fundamental switch mode power supply circuits: https://recom-power.com/en/rec-n-an-introduction-to-buck,-boost,-and-buck!sboost-converters-131.html?0
Your circuit indeed matches the buck-boost model. The output polarity is inverted which is important to note if you are using a polarised capacitor. The diode should also be a fast switching type.
The feedback loop has to be quite responsive to control a boost converter and this is best realised using an analog circuit. Using a microcontroller to read an analog voltage, convert it to a digital representation then use that to adjust the duty cycle of a timer is rather heavy weight.
Here is a very simple but effective boost converter using a 555 timer IC. I've tested such a circuit up to about 350 volts. As for the layout, it is best to keep the feedback circuit away from the inductor. 50 - 555 Circuits
I was testing some Buck Converter cct's this week and then saw an advert for a 9A 300W Buck converter .. at that price I order 5 will receive it today.
For educational purposes yes play around.
I do not understand how you are going to get 90V out of a buck converter with 12V in. If it were a boost or SEPIC converter that would make sense to me.
hello, thanks for all the replies. Heres some updates and a bit more info i probably should of added:
(Edit: sorry i keep mixing up buck and buck-boost converter) 60v from a (buck-boost) converter is perfectly possible, already have one tl494 based 12v to 60v stepup however i need two step-ups and im a little tight on budget right now
this leads me on to what the load is going to be, im going to be powering a +-60v amplifier which will be drawing about 500w, im doing this by using two isolated 12v 30A smps power supplies going into two separate boost converters. This means each boost converter will be handling 250w.
So far i have moved onto a new circuit that sends feedback to the Arduino nano. the nano changes the duty cycle based on the voltage feedback (of course run through a voltage divider)
int potentiometer = A0; //The input from the potentiometer is A0
int feedback = A1;      //The feedback input is A1
int PWM = 3;            //Digital pin D3 por PWM signal
int pwm = 250;            //Initial value of PWM width
  pinMode(potentiometer, INPUT);
  pinMode(feedback, INPUT);
  pinMode(PWM, OUTPUT);
  TCCR2B = TCCR2B & B11111000 | B00000001;    // pin 3 and 11 PWM frequency of 31372.55 Hz
  float voltage = 500;    //We read the value of the potentiometer, which is the desired value
  float output  = analogRead(feedback);         //We read the feedback, which is the real value
  //If the desired value is HIGHER than the real value, we increase PWM width
  if (voltage > output)
    Serial.println("trying to increase output voltage. pwm: " + String(pwm));
    pwm = pwm-1;
    pwm = constrain(pwm, 1, 254);
    delay(90);
  //If the desired value is LOWER than the real value, we decreaase PWM width
  if (voltage < output)
    Serial.println("trying to decrease output voltage. pwm: " + String(pwm));
    pwm = pwm+1;
    delay(90);
   analogWrite(PWM,pwm);  //Finally, we create the PWM signal
  • on 500 ohm load, the buck-boost converters output jumps up to 120v, the arduino attempts to pull the voltage back down by increasing the duty cycle to around ~90%, however it struggles to pull it back to 60v
  • on no load arduino is managing to hold the buck boost converter at 60v, however it is very unstable, as expected of a microcontroller
  • the mosfet im using /SVF7N65F is getting pretty hot, can anyone recommend me a better switching mosfet? i have lots of large transistors around from old power supplies, would a transistor be more effective e.g 2sc2625 NPN
    note I am not using a potentiometer, the potentiometers value is pre-set to 500 on the float "voltage"
    I would rather not buy buck boost converter boards as personally it would be nice to try and make one especially with all the parts i have hanging around
No base resistor on the BJT, how is that working for you :wink:
i can confirm that it is working, or at least idling at 60v.
For how long will it keep working?
See post #10...
3 hours so far, ill put a resistor on it to be safe.
Not to be safe....
...to keep current below max pin current and below max be current...
...thus preventing damage to board and or transistor...
is the transistor not isolated well enough to avoid any current getting back to the pin on the base?
The pin delivers the current to the base..
Ipin = Ibe
You must keep the Arduino output current within safe limits.
20mA is what we design around to prevent damage to output pins.
(5v (supply) - .7v (Vbe) ) / .02A = 215R use 220R
We can increase this resistor value if there’s need, but start with 220R.
The base of the transistor is clamped to 0.7V and the Arduino will try its best to raise that voltage to a logic one level... and will fail.
In this case 1k or higher will work just as well...
Not more than 100k!
Yes
The lowest is ~220R
However, a MOSFET would be recommended here instead of the BJT.
