BUGS with SH1106 Oled LCD 0.96"
Hello, recently I'm releasing a SH1106 OLED LCD 0.96", I've loaded text, bmp and xbm graphics without problem, however, at the time of making several tests in a row appears a line of pixels that I did not program, it happens with the Adafruit and u8g2 libraries, I have used "clearDisplay" or other similar functions and remains the same. The only way I have found to solve it is loading the same code but based on another library.
Is someone else getting the same problem? If so, could you share your solution? **Thank you! :slight_smile: **
[tt][b]Codes I have used[/b][/tt]
Adafruit
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define ANCHO 128
#define ALTO 64
#define OLED_RESET 4
Adafruit_SSD1306 oled(ANCHO, ALTO, &Wire, OLED_RESET);
const unsigned char PROGMEM navi5[] = {
//I deleted the bmp because exceeding the character limit of the post :(
  Wire.begin();
  oled.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  oled.clearDisplay();
  oled.drawBitmap(0, 0, navi5, 128, 64, WHITE);
  oled.display();
u8g2
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
static const unsigned char PROGMEM navi[] = {
//I deleted it xbm because exceeding the character limit of the post :(
U8G2_SH1106_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
void setup(void) {
  u8g2.begin();
void loop(void) {
  u8g2.firstPage();
  do {
    u8g2.drawXBMP(0, 0, 128, 64, navi);
    u8g2.setFont(u8g2_font_ncenB10_tr);
    u8g2.drawStr(0,24,"Hola");
  } while ( u8g2.nextPage() );
I have attached images of the problem
Please post a link to the actual display that you bought. e.g. Ebay sale page.
If you can't remember the purchase, search Ebay, AliExpress, ... for similar displays.
Compare photos in the links with the pcb on your desk. Post that link explaining that "the pcb looks exactly like my one".
It is always wise to run the examples supplied with a library.
If you have a problem, you just have to say library_xyz installed by IDE Library Manager, example_abc.ino
There is no need to attach or paste a publicly available library example.
If examples all work 100%, say so.
If the problem is with your custom sketch, attach the files if they are too big to paste.
David.
The Adafruit code you posted looks like it is for a SSD1306, but you said you had a SH1106 ?
