Build third world communities to help with project to cut wire at certain length from YouTube
I am new here and I am building some project to build third world communities to help with project to cut wire at certain length from YouTube
Here is the link https://www.youtube.com/watch?v=_dAJtTnHLYg
I would like to have some expertise advice to/or modify the code only to move servo motor to max speed and steeper motor to synchronizing with it
Everything s are working well but the servo motor is so slow
How can I speed the servo motor?
Can someone please modify the code to speed up and repost here because I am not a programmer or coder.
I really appreciate your time and help to help
  Youtube  : https://www.youtube.com/c/403ERRORVN
  Fanpage  : https://www.facebook.com/403ERRORVN
  Blog     : https://thichchetaotv.blogspot.com/
  Date     : 19/08/2022
  Update   : 19/08/2022
//------------------------------- librarys ----------------------------------
#include <LiquidCrystal.h>
#include <Servo.h>
//------------------------------- lcd ----------------------------------
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
//------------------------------- stepper ----------------------------------
#define stepPin 8
#define dirPin 9
//------------------------------- servo ----------------------------------
Servo snippers;
#define servo 10
#define openAngle 0           // Góc ban đầu của Servo
#define closedAngle 140          // Góc khi Servo cắt dây
//------------------------------- input ----------------------------------
#define leftButton A0
#define rightButton A3
#define upButton A2
#define downButton A1
//------------------------------- user settings ----------------------------------
unsigned int wireLength = 0;
unsigned int wireQuantity = 0;
//------------------------------- system settings ----------------------------------
int state = 0;
int incrementSpeed = 1;
int previousWireLength = 0;
int previousWireQuantity = 0;
float mmPerStep = 0.1681;
  lcd.begin(16, 2); //LCD columns and rows
  pinMode(upButton, INPUT_PULLUP);
  pinMode(downButton, INPUT_PULLUP);
  pinMode(leftButton, INPUT_PULLUP);
  pinMode(rightButton, INPUT_PULLUP);
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  snippers.attach(servo);
  snippers.write(openAngle);
  lcd.setCursor(0, 0);
    lcd.setCursor(0, 1);
    delay(2000);
  if (!digitalRead(rightButton)){
    if(state == 5){
      state = 0;
    else{
      state += 1;
    delay(200);
    lcd.clear();
  if (!digitalRead(leftButton) && state > 0 && state < 4){
    state -=1;
    delay(200);
    lcd.clear();
  switch (state){
    case 0:
      homeScreen();
    case 1:
       chooseWireLength();
    case 2:
      chooseWireQuantity();
    case 3:
      confirm();
    case 4:
      currentlyCutting();
    case 5:
      finishedCutting();
void homeScreen(){
  lcd.print("ABB WIRE CUTTER");
  lcd.setCursor(11, 1);
  lcd.print("NEXT>");
  delay(100);
void chooseWireLength(){
  wireLength = changeValue(wireLength);
  //clear LCD if required
  if(previousWireLength != wireLength){
    lcd.clear();
    previousWireLength = wireLength;
  //Display information on LCD
  lcd.print("LENGTH:" + (String)wireLength + "mm");
  displayNavigation();
void chooseWireQuantity(){
  wireQuantity = changeValue(wireQuantity);
  if(previousWireQuantity != wireQuantity){
    lcd.clear();
    previousWireQuantity = wireQuantity;
  lcd.print("QUANTITY:" + (String)wireQuantity);
void confirm(){
  lcd.print((String)wireLength + "mm x " + (String)wireQuantity + "pcs");
  lcd.print("<BACK");
  lcd.setCursor(10, 1);
  lcd.print("START>");
  delay(100);
void currentlyCutting(){
  lcd.print((String)0 + "/" + (String)wireQuantity);
  lcd.print("???s");
  int stepsToTake = (int)wireLength/mmPerStep;
  for(int i = 0; i < wireQuantity; i++){
    unsigned long timeForOneCycle = millis();
    digitalWrite(dirPin,HIGH);
    for(int x = 0; x < stepsToTake; x++) {
      digitalWrite(stepPin,HIGH);
      delayMicroseconds(500);
      digitalWrite(stepPin,LOW);
    lcd.print((String)(i+1) + "/" + (String)wireQuantity);
    snippers.write(closedAngle);
    unsigned long timeRemaining = ((millis() - timeForOneCycle)*(wireQuantity - (i+1)))/1000;
    lcd.print((String)timeRemaining + "s    ");
  wireLength = 0;
  wireQuantity = 0;
  state = 5;
void finishedCutting(){
  lcd.clear();
  lcd.print("CUTTING COMPLETE");
  lcd.print("NEXT>");
  delay(100);
int changeValue(int currentValue){
  if (!digitalRead(upButton)) {
    currentValue += incrementSpeed;
    incrementSpeed ++;
  if (!digitalRead(downButton)) {
    if(currentValue - incrementSpeed >= 0){
      currentValue -= incrementSpeed;
      incrementSpeed ++;
    else{
      currentValue = 0;
  if (digitalRead(downButton) && digitalRead(upButton)){
    incrementSpeed = 1;
  return currentValue;
void displayNavigation(){
  lcd.print("<BACK");
  lcd.print("NEXT>");
  delay(100);
`> type or paste code here`
A servo motor is pretty much fixed in its torque/speed, there is nothing really you can do to improve it.
I think you will need to use a more powerful motor.
Please define "so slow".
There's certain some time to be save by reducing these delays.
Real world wire cutters use a solenoid to operate the cutter!
If "they" can make "that" (electrical infrastructure, computer systems, CAD, LASER cutter, precision milling machine, 3D printer) "they" are not "third world."
Why not just make yourself a wire-cut-to-length project? It is a lot of fun.
Tip: scrub to the 17 minute mark. Life is very short.
a7
IF you think this thread is complete, please mark it as solved!
