Hi @Johan_Ha.
It is possible to create and modify dashboards via code by using the Arduino Cloud IoT API:
https://docs.arduino.cc/cloud-api/
The first step is to create an Arduino Cloud API key:
https://docs.arduino.cc/arduino-cloud/api/arduino-iot-api/#api-keys--authentication
ⓘ API keys are only available when using a "Maker" Arduino Cloud plan (or higher).
Next, you must create an authentication token from your API key to use in the API requests:
https://docs.arduino.cc/cloud-api/#:~:text=Properties%20and%20Timeseries.-,Create%20Auth%20Token,-This%20API%20can
For example, using the curl and jq tools from a POSIX shell:
$ ARDUINO_CLIENT_ID=<your client ID>
$ ARDUINO_CLIENT_SECRET=<your client secret>
$ ARDUINO_TOKEN="$(
curl \
--request POST \
--url "https://api2.arduino.cc/iot/v1/clients/token" \
--header "content-type: application/x-www-form-urlencoded" \
--data "grant_type=client_credentials" \
--data "client_id=$ARDUINO_CLIENT_ID" \
--data "client_secret=$ARDUINO_CLIENT_SECRET" \
--data 'audience=https://api2.arduino.cc/iot' \
jq \
--raw-output \
'.access_token'
Lets say you want to add a new value with label "baz" and value "123" to a "Value Dropdown" widget in an existing dashboard. You would then get the data for the dashboard:
https://docs.arduino.cc/cloud-api/dashboards-api/#Dashboards%20V2%20List
$ curl \
--request GET \
--header "Authorization: Bearer $ARDUINO_TOKEN" \
"https://api2.arduino.cc/iot/v2/dashboards" \
jq .
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 421 100 421 0 0 1349 0 --:--:-- --:--:-- --:--:-- 1358
"created_by": {
"user_id": "e47d8721-f9b6-4f49-b2e3-96dffdb5b98f",
"username": "ptillisch"
"id": "92ac8caf-e91e-49ba-859d-49a41ef2be98",
"name": "Untitled Dashboard",
"updated_at": "2025-11-06T05:05:11.296676Z",
"widgets": [
"height": 3,
"id": "c1cc791d-e1ad-4a75-ba91-f4e65bb4bd21",
"options": {
"values": [
"label": "foo",
"value": 11
"label": "bar",
"value": 42
"type": "Value Dropdown",
"width": 9,
"x": 0,
"y": 0
Then patch the dashboard:
$ ARDUINO_DASHBOARD_ID="92ac8caf-e91e-49ba-859d-49a41ef2be98"
$ curl \
--request PATCH \
--header "Content-Type: application/json" \
"https://api2.arduino.cc/iot/v2/dashboards/$ARDUINO_DASHBOARD_ID" \
--data '
"widgets": [
"height": 3,
"width": 9,
"x": 0,
"y": 0,
"options": {
"values": [
"label": "foo",
"value": 11
"label": "bar",
"value": 42
"label": "baz",
"value": 123
jq .
100 1094 100 449 100 645 1439 2068 --:--:-- --:--:-- --:--:-- 3529
"created_by": {
"updated_at": "2025-11-06T05:11:02.573918Z",
"widgets": [
"has_unlinked_variable": false,
"height": 3,
"options": {
"values": [
"label": "foo",
"value": 11
"label": "bar",
"value": 42
"label": "baz",
"value": 123
"width": 9,
"x": 0,
"y": 0
I performed the requests using curl for the sake of simplicity, but you can also do this using your favorite programming language, which will be more appropriate for anything more involved than an occasional simple operation like shown above.
Arduino Cloud CLI?
There is a command line tool for managing Arduino Cloud IoT projects, named Arduino Cloud CLI:
https://docs.arduino.cc/arduino-cloud/arduino-cloud-cli/getting-started/#create-dashboard
For simple operations, this is much more convenient to use than the API. Unfortunately, there are some limitations that make it not meet the requirements of your specific use case:
- Arduino Cloud CLI doesn't have the capability to modify an existing dashboard; only to create a new dashboard.
- Arduino Cloud CLI doesn't use the set of widget option values specified in the template code, but instead simply creates a widget with the default options.
Although it would be inconvenient and possibly problematic for some use cases, the former limitation could be worked around to some extent by deleting the previous dashboard after creating the new one. However, I think the latter limitation is likely a show stopper for you.
