I would like to Play with LED Multiplexing by Building digital clock
This would work like 4x7 LED batrix which each 7LEDs would make 7 Segment Digit.
I wanted to use leds which would be easy to solder and I came accross LILYPAD LEDs available online
https://pl.aliexpress.com/item/10pcs-lot-LilyPad-Led-Red-White-Orange-Emerald-Green-Blue-Yellow-
Yellow-Green-Light-Module-For/32583987549.html?spm=a2g17.10010108.1000023.2.7d1a624dCGVv2M
I wanted to use BC547 Transistors to Switch individual Digit I want to lit at any Point in time. A mit like diagram in the below link (Figure1)
So planning to have 4 Transistor which would select which Digit I want to lit and then within that Digit light all necesssry leds
Lighting each Digit one by one.
The Chart in this example Shows only resistors used with Transistors. But do I Need any resistors when connecting LEDs. Would that 7x4 Matrix work using VCC powered by VCC port of arduino or do I have to consider external power.
If I Need to use external power (e.g. 5V 2A) does it Change anything in Terms of resistors needed
