I have been researching this stuff since I am planning to do a SAMD21 board soon but have not done it yet. Anyway...
I think for the bootloader to become active when the USB is plugged in, it will need an application firmware loaded. It is sort of a chicken and egg problem, the bootloader alone is probably not looking for the USB event (open and close serial port at 1200 bps) that runs the bootloader (it is cooked into the Arduino core, so will be missing from images built from Studio, mbed, or any other toolchain). Since the bootloader does not run the USB serial looks dead, I have no idea what a good fix would be, but as a hack, I think you could force it into bootload mode with a double tap on the reset button and then the serial should show up, and the SAM-BA bootloader should be running and watching that port.
Just a quick update here.. (i'm working with OP Ban on this)
On Ban's computer (Parallels Windows 10 on MBP) he gets a Code 10 (This Device Cannot Start), but the device descriptor seems to be transmitted (he gets a valid product id / vendor id, and it says something like 'Arduino Bootloader'
If I plug the same board into my computer I get a Code 43 - Invalid Configuration Descriptor. I don't get a vendor or product ID.
I managed to upload the bootloader manually through the STLink using OpenOCD without any errors (took a bit of fiddling but worked in the end). But that doesn't mean that the USB works.
We've tested this on 2 boards now with the same error, which somewhat rules out random issues in fabrication
Thank you for the response ron!
interesting read in the other thread
Aren't all the pin assignments handled by uploading the arduino bootloader?
another note
We tried the double tap reset
Also tried 'reset run' from OpenOCD which seems to do the same thing.
Often after flashing, it's necessary to do that reset before it shows up in the system at all (but still that's when it shows up as Code 43 or Code 10)
Also just in case there's any confusion. We are trying to get the native USB port to function (we haven't got any headers connected to the serial pins on our board).
Also i'm wondering if there's something electrical we might have missed (e.g. you have to pull down some pin or other to ground if you want to use the USB pins as a USB device)
for reference. we're trying to make a motor driver board. it is for an art installation and the designs will be released online for free.
Once the Arduino Zero bootloader has been uploaded, you should be able to upload sketches over the native USB port.
For the USB to function correctly the SAMD21 should be driven by an external 32.768kHz crystal on port pins PA0 and PA1. (The microcontroller's internal oscillator isn't accurate enough).
Other than that there aren't any special requirements in terms of pins being pulled high or low, except for the RESET pin (pulled high). The USB only requires that the D+ and D- lines are connected to the corresponding microcontroller pins.
On connecting the USB the SAMD21 should normally enumerate as: "Arduino Zero (COMx)", or "Arduino Zero bootloader (COMx)" in bootloader mode, (after double tap on reset).
As MartinL mensioned,
1.We have the external 32.768kHz crystal on PA0 and PA1.
2.Reset button has pulled high resistor (the resistor seems a bit high, 10k+330 ohm. I refered arduino zero's schematic)
3.We originally planed to use USB hub chip (USB2514), but at the end, we connected D+,D- cables to SAMD21 chip directly for testing. (we also cut the lines from USB2514 and ESD chip)
But still exactly same situation.
I can see 'Arduino Zero bootloader(COM3)' in bootloader mode, but It doesn't work with 'code 10' error msg in windows 10.
In schematic, I couldn't find any significant difference with arduino zero or other SAMD21 references.
I'm wondering that if I placed the components too close, it cause the unstable voltage that can be problem of this.
Hi, I have the same results as the OP, but I am using a cheap SAMD21 Arduino M0 (not Pro) clone.
I think one key is that according to the log, the programming succeeded, but the readback verification reads all 0xFF instead of the real data (this is from my verbose log):
18552 bytes written at address 0x00000000
downloaded 18552 bytes in 0.438170s (41.347 KiB/s)
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x2000002e msp: 0xfffffffc
Error: checksum mismatch - attempting binary compare
diff 0 address 0x00000000. Was 0xff instead of 0xfc
diff 1 address 0x00000001. Was 0xff instead of 0x7f
diff 2 address 0x00000002. Was 0xff instead of 0x00
diff 3 address 0x00000003. Was 0xff instead of 0x20
diff 4 address 0x00000004. Was 0xff instead of 0x15
I would be interested if anyone has successfully programmed the SAMD21 with the ST-Link V2 adapter.
If you check this video : https://www.youtube.com/watch?v=VQWhjzLoHB8
It seems to show a SAMD21 chip on a custom PCB being flashed with the Arduino Zero bootloader successfully
It needn't be that complicated.
I just used Atmel-ICE Basic programmer connected to a 2x5 way, 1.27mm pitch, SWD connector on my custom board. The board was powered via its native USB port.
On the Arduino IDE: Tools->Programmer->Atmel SAM ICE, followed by Tools->Burn Bootloader.
Thereafter, it's possible to remove the Atmel ICE programmer from the SWD port and upload sketches via your custom board's native USB with the Arduino Zero bootloader.
Unfortunately, since Microchip's acquistion of Atmel, the cost of the Atmel-ICE has more than doubled.
Here's a quick update. I borrowed an Atmel-ICE and used Atmel Studio to try to program the board. I learned that the BOOTPROT bits were set to protect the bootloader region (the value was 0x01). I set the value to 0x07 (disabled) and afterward I was able to use ST-Link to program the bootloader.
Unfortunately I am not aware of any way to change the BOOTPROT register with Adalink. Adalink is just a set of Python scripts, so maybe I'll do some investigating.
Can you also use that JLink Mini Edu within the Arduino IDO to flash a bootloader? Will it show up in the Arduino Software or is it only with AtmelStudio compatible?
anyone succeed using STLink to burn the bootloader ??
I did a bit of web searching, and found mostly complaints that it doesn't work.
Apparently the STLink firmware doesn't support 16-bit writes over SWD, and a SAMD chip doesn't work when certain 16bit quantities are written 8 bits at a time. Or something like that.
