Burn Bootloader -> Arduino as iso
I keep reading that under the tools menu there is a burn bootloader option that has a sub menu under it that gives you the option "burn boot loader arduino as isp". Mine doesn't have that. It is just "burn boot loader" with no sub-menu. Where can I find the burn bootloader arduino as isp command?
You select the "Arduino as ISP" Programmer in the Tools->Programmer menu, select the target board in Tools->Board and then select Tools->Burn Bootloader
johnwasser:
Thanks!
