i think you have less idea then me...
i try to explaine more excately for you:
at my left there is my breakout board with 30 rows and 5 rows, which are marked with the letters f, g, h, i and j.
in this breakout board there are cables with different color. some cables are green, yellow, orange (a bright orange). but i have some fancy colors too, which looks more like neon.
two wires (green and blue) are connected to the laptop charging device. green for + and blue for -.
i was struggeling with myself, cause usually i like the color red and black for the source, but after few seconds i took the blue and the green one. cause it was too chaotic in my wooden wire box to find a cable with 2 females.
when i make the test with the current source i have a signal generator where i can turn a small knob, which is black whith a small white dot on it. this outputs an source between another 2 cables which have the same color - crazy, i know (green and blue). oh, i forgot to mention - the green and blue wires connected to the power supply for the generator.
back to the output. this output deliver 20mA to the green cable and the blue is the reference of the generator (GND). when i rotate the small knob (previously mentioned) counterclockwise, the current decrease to 0mA. whe i still rotate it, it changes the output to the blue cable and now the green cables is the reference GND.
this cables are connected to the shunt 10ohm resistor. the green cable is also connected to the A0, and the blue to the A1. then i can activate the differential mode and the ADS1115 take the reference between A0 and A1 - not to the GND in the ADC.
so... now i test the voltage thing....
i removed all this stuff except the power supply on my breakout board (19V).
the wires still blue and green.
then i have searched a while to find the correct resistors.
after this i took the resistors and plugged it into the breakout board, so that i have connection to the green cable, which is now the positive (19V).
then i put the resitor next to the other one and connected it to the blue cable, which is 0V.
now i connect the green (of the A0 from ADC) to the middle of the voltage devider, and a second blue wire (to A1 of ADC) to the existing blue 0V wire.
now i tested it with my small voltmeter and the voltage was correctly devided.
then i connected the ADC.... now it was making booom... small white smoke was visible... like right after they have choosen the pope in the good old vatican sometimes...
when i want to make a minus V input i can easy change the blue and the green cable... but i didnt reached this step of the test...
now i have that much time to explain you the wiring and color of my circuit. previously i thought its easier to make a more professional circuit diagram like this one at my first post. but sometimes people dont understand it correctely.
