avrdude: verification error, first mismatch at byte 0x1fc00
0xff != 0x1f
avrdude: verification error; content mismatch
Error while burning bootloader.
I do have Usbtinyisp selected under programmer so believe it should work lol.
Not sure where to go from here.
Thanks in Advance for the help
bootloader and Marlin are two different things. if yo don't want to use integrated USB port for uploads so bootloader is unnecessary. Upload Marlin FW via ISCP. check fuses. but to do this you need to test your programmer and board
Hi Kolaha, yep sorry maybe my bad. Im just using marlin to burn the bootloader onto the board for now so that i can update via the usb on the printer later on. When i hit burn bootloader the error message above shows. There is a green light on the icsp that turns red when i try burn the bootloader. not sure if this is just showing a response to the command. How would one go about testing the board and the programmer as you mentioned above?
I have a v4.2.2 ender 3 pro motherboard board, how can i burn a bootloader on that? Through ISCP...i cant, or i dont know how, you have 4 pins, where should i connect them on my arduino that has 6 ..?
