Hi. In this program, when Uxf or Uyf are displayed separately on the serial plotter, they are displayed correctly, but when they are displayed simultaneously, the filtered Uxf and Uyf values are the same, where not filtered Ux Uy are different. What is wrong with the code?
Ux = -1145.39 Uxf = -782.38 Uy = -409.36 Uyf = -782.36
Ux = -1145.32 Uxf = -782.36 Uy = -409.38 Uyf = -782.36
Ux = -1145.46 Uxf = -782.37 Uy = -409.43 Uyf = -782.37
Ux = -1145.47 Uxf = -782.38 Uy = -409.44 Uyf = -782.38
Ux = -1145.34 Uxf = -782.39 Uy = -409.43 Uyf = -782.40
//PINS generator 3,12, 13, 15,21,
4 Tx
0 comp
32 0 deg
33 90 deg
21 Tx dedtime
//PINS analog 32,33,35, 36, 39,
32 detector x
33 amp x
35 detector y
34 amp y
36 mA
39 bat
ADS1220
23 mosi
19 miso
27 csx
33 csy
#include <Filters.h>
#include <AH/Timing/MillisMicrosTimer.hpp>
#include <Filters/Butterworth.hpp>
#include <ADS1220_WE.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h>
#include <SPI.h>
#include <driver/ledc.h>
#include <Preferences.h>
Preferences preferences;
#define TFT_MOSI 23 // Data out
#define TFT_SCLK 18 // Clock out
#define TFT_CS 22//
#define TFT_DC 21 //
#define TFT_RST -1 // pin# 2
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
//================================ ADS =============================
// Pin definitions
#define SPI_MISO_PIN 19
#define ADS1220_1_CS_PIN 25 // Chip Select
#define ADS1220_1_DRDY_PIN 34 // Data Ready
#define ADS1220_2_CS_PIN 26 // Chip Select
#define ADS1220_2_DRDY_PIN 35 // Data Ready
#define SPI_INITIALIZED true
#define SPI_NOT_INITIALIZED false
/* Create ADS1220 objects */
ADS1220_WE ads1 = ADS1220_WE(ADS1220_1_CS_PIN, ADS1220_1_DRDY_PIN);
ADS1220_WE ads2 = ADS1220_WE(ADS1220_2_CS_PIN, ADS1220_2_DRDY_PIN);
//=============================== end ADS ======================
//=========================== ADS =============================
while (!Serial);
/* Choose SPI clock speed here. */
// ads1.setSPIClockSpeed(4000000); // set SPI clock speed, default is 4 MHz
// ads2.setSPIClockSpeed(4000000);
digitalWrite(ADS1220_1_CS_PIN, HIGH);
pinMode(ADS1220_1_CS_PIN, OUTPUT);
digitalWrite(ADS1220_2_CS_PIN, HIGH);
pinMode(ADS1220_2_CS_PIN, OUTPUT);
if (ads1.init()) {
if (ads2.init()) {
ads1.setGain(ADS1220_GAIN_1);
ads1.setDataRate(ADS1220_DR_LVL_2);
ads1.setConversionMode(ADS1220_CONTINUOUS);
ads2.setGain(ADS1220_GAIN_1);
ads2.setDataRate(ADS1220_DR_LVL_2);
ads2.setConversionMode(ADS1220_CONTINUOUS);
float vRef1 = ads1.getVRef_V();
float vRef2 = ads2.getVRef_V();
//=========================== end ADS =============================
pinMode(22, OUTPUT);
pinMode(5, INPUT_PULLUP); //amp ++
pinMode(17, INPUT_PULLUP); // amp --
pinMode(12, INPUT_PULLUP); //phase ++
pinMode(14, INPUT_PULLUP); // phase --
pinMode(2, INPUT_PULLUP); // sw
ledc_timer_config_t timerConfig = {
.speed_mode = LEDC_LOW_SPEED_MODE,
.duty_resolution = LEDC_TIMER_10_BIT,
.timer_num = LEDC_TIMER_0,
.freq_hz = 15300,
.clk_cfg = LEDC_AUTO_CLK
ledc_timer_config(&timerConfig);
//0°,F1
ledc_channel_config_t channelConfig1 = {
.gpio_num = 32,
.channel = LEDC_CHANNEL_0,
.timer_sel = LEDC_TIMER_0,
.duty = 512,
.hpoint = 0
ledc_channel_config(&channelConfig1);
//90°, F2
ledc_channel_config_t channelConfig2 = {
.gpio_num = 33,
.channel = LEDC_CHANNEL_1,
.duty = 512,
.hpoint = 256
ledc_channel_config(&channelConfig2);
//F3 , Tx GB
ledc_channel_config_t channelConfig3 = {
.gpio_num = 4,
.duty = 512,
.hpoint = 0
ledc_channel_config(&channelConfig3);
// F4 comp
ledc_channel_config_t channelConfig4 = {
.gpio_num = 0,
.duty = 512,
.hpoint = 0
ledc_channel_config(&channelConfig4);
//GB, F4
ledc_channel_config_t channelConfig5 = {
//.gpio_num = 32,
//.gpio_num = 16,
// .gpio_num = 4,
.gpio_num = 15,
.duty = 512,
.hpoint = 0
ledc_channel_config(&channelConfig5);
const double f_s = 100; // Hz
// Cut-off frequency (-3 dB)
const double f_c = 12; // Hz
// Normalized cut-off frequency
const double f_n = 2 * f_c / f_s;
// Sample timer
Timer<micros> timer = std::round(1e6 / f_s);
// Sixth-order Butterworth filter
auto filter = butter<6>(f_n);
//if (timer)
ads1.setCompareChannels(ADS1220_MUX_0_1);
float Ux = ads1.getVoltage_mV();
// Ux = ads1.getVoltage_muV();
ads2.setCompareChannels(ADS1220_MUX_0_1);
float Uy = ads2.getVoltage_mV();
// Uy = ads2.getVoltage_muV();
Serial.print(" Ux = ");
Serial.print(Ux + 5 );
Serial.print(" Uxf = ");
Serial.print(filter(Ux));
Serial.print(" Uy = ");
Serial.print(Uy + 5 );
Serial.print(" Uyf = ");
Serial.print(filter(Uy));
