Without the buttons my circuit just one side works ok, when i put the button the circuit "play alone" the game
This is the code:
bool willTheBallGoTowardsPlayerTwo = true;
bool isInputAllowed = true;
const int playerOne = 12;
const int goalPlayerOne = 13;
const int buttonPlayerOne = 3;
const int playerTwo = 5;
const int goalPlayerTwo = 4;
const int buttonPlayerTwo = 2;
int scoreOfPlayerOne = 0;
int scoreOfPlayerTwo = 0;
const unsigned long initialMillisecondsPerLED = 500;
const unsigned long initialDeltaMillisecondsPerLED = 50;
unsigned long millisecondsPerLED = initialMillisecondsPerLED;
unsigned long deltaMillisecondsPerLED = initialDeltaMillisecondsPerLED;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
int currentPosition = playerOne; //Player one starts the game.
int previousPosition = playerOne + 1;
int deltaPosition = 0;
int buttonStatePlayerOne = 0;
int lastButtonStatePlayerOne = 0;
int buttonStatePlayerTwo = 0;
int lastButtonStatePlayerTwo = 0;
pinMode(4, 1);
pinMode(5, 1);
pinMode(6, 1);
pinMode(7, 1);
pinMode(8, 1);
pinMode(9, 1);
pinMode(10, 1);
pinMode(11, 1);
pinMode(12, 1);
pinMode(13, 1);
/*Connect pins 4 to 13 to 220ohm(or higher) resistors, connect the LEDs' longer legs(+) to the resistors,
connect the other legs(-) of the LEDs' to ground.
I recommend red LEDs for 4 and 13(Goals), yellow LEDs for 5 and 12(Players), green LEDs for other pins(Field).
pinMode(2, 0); //Pushbuttons for players. Pin 2 is for player two. Pin 3 is for player one.
pinMode(3, 0); //Connect pushbuttons following the instructions on this page: https://www.arduino.cc/en/Tutorial/DigitalReadSerial
ListenForInput();
currentMillis = millis();
if (currentMillis - previousMillis >= millisecondsPerLED) //If you don't understand this, see: https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
CheckGoalConditions();
DetermineNextPosition();
MoveBallToNextPosition();
void ListenForInput() //If you don't understand this method, see: https://www.arduino.cc/en/Tutorial/StateChangeDetection
buttonStatePlayerOne = digitalRead(buttonPlayerOne);
buttonStatePlayerTwo = digitalRead(buttonPlayerTwo);
if (buttonStatePlayerOne != lastButtonStatePlayerOne && isInputAllowed)
if (buttonStatePlayerOne == 1)
if (currentPosition == playerOne)
ToggleBallDirection();
IncreaseSpeed();
ScoreForPlayer(2);
lastButtonStatePlayerOne = buttonStatePlayerOne;
if (buttonStatePlayerTwo != lastButtonStatePlayerTwo && isInputAllowed)
if (buttonStatePlayerTwo == 1)
if (currentPosition == playerTwo)
IncreaseSpeed();
ScoreForPlayer(1);
lastButtonStatePlayerTwo = buttonStatePlayerTwo;
void ToggleBallDirection()
willTheBallGoTowardsPlayerTwo = !willTheBallGoTowardsPlayerTwo;
isInputAllowed = false; //Only one direction change per frame is allowed for consistent gameplay.
void IncreaseSpeed()
millisecondsPerLED -= deltaMillisecondsPerLED;
if (deltaMillisecondsPerLED > 5) //Because of this, it takes a little more time to reach to an insane speed. Adjust or remove this if rounds become too long.
deltaMillisecondsPerLED -= 5;
void MoveBallToNextPosition() //Moves the ball one spot.
previousPosition = currentPosition;
digitalWrite(previousPosition, 0);
currentPosition = currentPosition + deltaPosition;
digitalWrite(currentPosition, 1);
void DetermineNextPosition()
if (willTheBallGoTowardsPlayerTwo)
deltaPosition = -1;
deltaPosition = 1;
void CheckGoalConditions()
if (currentPosition == goalPlayerTwo)
ScoreForPlayer(1);
else if (currentPosition == goalPlayerOne)
ScoreForPlayer(2);
void ScoreForPlayer(int playerWhoScored)
FlashAllLEDs(1, 0);
if (playerWhoScored == 1)
scoreOfPlayerOne++;
ShowScores(1);
else if (playerWhoScored == 2)
scoreOfPlayerTwo++;
ShowScores(2);
CheckEndGame();
void CheckEndGame()
if (scoreOfPlayerOne == 3)
EndGameCeremonyFor(1);
if (scoreOfPlayerTwo == 3)
EndGameCeremonyFor(2);
void ShowScores(int playerCurrentlyScored)
if (playerCurrentlyScored == 1)
digitalWrite(playerOne, 1);
else if (playerCurrentlyScored == 2)
digitalWrite(playerTwo, 1);
currentPosition = playerTwo;
willTheBallGoTowardsPlayerTwo = false;
for (int i = 0; i < scoreOfPlayerOne; i++) //We use the six LEDs in the middle to show score. Each player has three green LEDs to show score. This is why three goals win the game ![]()
digitalWrite((11 - i), 1);
for (int i = 0; i < scoreOfPlayerTwo; i++)
digitalWrite((6 + i), 1);
delay(3000); //Are three seconds enough for players to process the score?
ResetValuesForNextRound();
void ResetValuesForNextRound()
FlashAllLEDs(1, 0);
millisecondsPerLED = initialMillisecondsPerLED; //Sets speed to initial value at the beginning of each round.
deltaMillisecondsPerLED = initialDeltaMillisecondsPerLED; //Sets delta speed to initial value at the beginning of each round.
void EndGameCeremonyFor(int winner)
FlashAllLEDs(50, winner);
TurnOffAllLEDsForPlayer(0);
void TurnOnAllLEDsForPlayer(int player)
if (player != 1) //When this method is called with (2), only these pins(player two's) will turn on
digitalWrite(4, 1);
digitalWrite(5, 1);
digitalWrite(6, 1);
digitalWrite(7, 1);
digitalWrite(8, 1);
if (player != 2) //When this method is called with (1), only these pins(player one's) will turn on
digitalWrite(9, 1);
digitalWrite(10, 1);
digitalWrite(11, 1);
digitalWrite(12, 1);
digitalWrite(13, 1);
void TurnOffAllLEDsForPlayer(int player)
if (player != 1) //When this method is called with (2), only these pins(player two's) will turn off
digitalWrite(4, 0);
digitalWrite(5, 0);
digitalWrite(6, 0);
digitalWrite(7, 0);
digitalWrite(8, 0);
if (player != 2) //When this method is called with (1), only these pins(player one's) will turn off
digitalWrite(9, 0);
digitalWrite(10, 0);
digitalWrite(11, 0);
digitalWrite(12, 0);
digitalWrite(13, 0);
void FlashAllLEDs(int blinkCount, int player) //Second parameter(int player) is for when you want to flash only one player's LEDs. Use 1 for player one, use 2 for player two.
for (int i = 0; i < blinkCount; i++)
TurnOnAllLEDsForPlayer(player);
delay(35);
TurnOffAllLEDsForPlayer(player);
delay(35);
Any help?
