Sorry if this is the wrong section of the forum to be posting this, but I'm having a problem with button debouncing in my sketch. When I press the button once it is registering several button presses at once instead of just one.
I'm using the example debouncing code from https://www.arduino.cc/en/Tutorial/BuiltInExamples/Debounce in my sketch and when I run this example in a standalone sketch it works as expected, registering just one button press each time I press the button so I think it is a problem with my sketch, specifically.
I'm running this on a Wemos D1 Mini and using platformio as my IDE. My sketch code is below:
#include <Arduino.h>
// The LED will begin blinking every second, then the interval variable will be decremented by
// 50 milliseconds each time the switch is pressed, making the LED blink progressively faster
// until the interval variable is 50 milliseconds at which point it will reset to 1000 milliseconds
// and pressing the switch will decrement the interval variable again
int switchstate; // stores the current state of the switch (HIGH or LOW)
int lastswitchstate = LOW; // stores the last known state of the switch
unsigned long lastdebouncetime = 0; //Stores the last time the button was pressed
unsigned long debouncedelay = 100; //the debounce time in milliseconds.
int ledPin = 5; //led pin (D1 on wemos D1 Mini)
int switchpin = 16; //Switch pin (D0 on Wemos D1 mini)
unsigned long interval = 1000; //Starting interval between LED blinks in milliseconds
unsigned long previousMillis = 0; //stores the last time the led was updated
int ledState = LOW; // stores the state of the LED
unsigned long currentMillis = 0;
//setup the serial port, 9600 baud
//set led pin as an output
pinMode(ledPin, OUTPUT);
//set switch pin as an input
pinMode(switchpin, INPUT);
// read the state of the switch pin into a local variable
int reading = digitalRead(switchpin);
// check to see if the button was pressed (LOW to HIGH transition)
// and we've waited long enough since the last press to avoid any noise
if(reading != lastswitchstate){
//reset the debouncing timer
lastdebouncetime = millis();
if ( (millis() - lastdebouncetime) > debouncedelay ){
//whatever the reading is at, its been there longer than than the debounce delay
//so this will be its actual state
//Serial.println("millis - lastdebouncetime is more than debounce delay");
//if the button has changed
if(reading != switchstate){
switchstate = reading;
Serial.println("switchstate set equal to reading");
//Decrement the interval variable by 50 if the switch state is high (pressed)
if(switchstate == HIGH){
interval = interval - 50;
Serial.println("interval reduced by 50ms");
// reset interval to 1000 if it reaches 50ms or less than 50ms
if(interval <= 50){
interval = 1000;
//blink the led at the frequency defined in interval
if(currentMillis - previousMillis > interval) {
previousMillis = currentMillis; // Save last time we blinked the LED
// If LED is off turn it on and visa-versa
if(ledState == LOW){
ledState = HIGH;
}else{
ledState = LOW;
// write state of led to the relevent pin
digitalWrite(ledPin, ledState);
// save the switch reading. next time through the loop it will be the lastswitchstate
lastswitchstate = reading;
Example of the output from the Serial.println debug lines for one button press is below
So it appears that the part of the sketch that decrements the interval variable is being run several times for each button press but I'm not sure why.
