I am trying to create a timer for my aeroponic system. The menu will display to choices.
Off time (which will be the amount of time in minutes that the timer will be off.
On time (which will be the amount of time in minutes that the timer will be on.
The timer "on time" will activate a solid state relay and will keep power on to my pump for the amount of time selected.
I pulled some code off the internet and would like some guidance.
Digital pins 5 and 6 are attached to tactile switches, they increment the on time variable.
I have added a 3rd tactile switch on digital pin 3, I would like this to be my "select button" which will let me choose whether I am working with "time off" or "time on"
Right now the following code is working and displays "Time On myVar.
I hope this makes sense, if not I will attempt to provide more information.
Thanks, John
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,8,9,10,11,12);
//Set buttons pin numbers
byte incrementButton = 5;
byte decrementButton = 6;
byte SelectButton = 3;
//Global variables
int incrementState = 0; //variable that will read the increment button (either HIGH or LOW)
int decrementState = 0; //variable that will read the decrement button (either HIGH or LOW)
int counter = 0; //variable that will store the count
int lastIncrementState = 0;
int lastDecrementState = 0;
pinMode(incrementButton, INPUT); //set incrementButton as INPUT
pinMode(decrementButton, INPUT); //set decrementButton as INPUT
lcd.begin(16, 2); //set up the LCD's number of columns and rows:
lcd.print("Time On"); //print a message on the LCD "Time On"
lcd.setCursor(0,2); //Set the cursor at row 2 to print next line
lcd.print("Time Off"); ////print a message on the LCD "Time Off"
}//end of setup
lcd.setCursor(12, 0);
incrementState = digitalRead(incrementButton); //read the increment button state
decrementState = digitalRead(decrementButton); //read the decrement button state
if(incrementState != lastIncrementState) //compare increment button state to its last state
if(incrementState == LOW)//increment button is pressed
counter = counter + 1; //increment the counter
lcd.print(counter); //print it on serial monitor
lcd.print(" "); //3 blank spaces
delay(20); //debounce delay
lastIncrementState = incrementState;
if(decrementState != lastDecrementState)//compare decrement state to its lastState
if(decrementState == LOW)//decrement button is pressed
counter = counter - 1; //decrement the counter
lastDecrementState = decrementState;
}//end of loop
So you want the third button to toggle between the two states? Ok, so then use a latch.
static boolean select = digitalRead(3);
if(select != lastSelectState) // lastSelectState will need to be declaired boolean too at the top of your code.
if(select == HIGH)
lastSelectState = select; // Notice I put this in here and not outside the if statement.
State = !State; // also declare boolean at the top of your code. Set to false
if(State == HIGH)
// code for time on
//time off
Aftrer looking at this, I guess I just don't understand it. I am going to try and re-describe my goal. Here is where I am at with my code, questions will be below.
//Global variables
int selectState = 0;
int led = 13;
pinMode(led, OUTPUT);
pinMode(SelectButton, INPUT); //set decrementButton as INPUT
}//end of setup
//lcd.setCursor(12, 0);
//incrementState = digitalRead(incrementButton); //read the increment button state
//decrementState = digitalRead(decrementButton); //read the decrement button state
//selectState = digitalRead(SelectButton); //read the Select button state
lcd.setCursor(12, 1);
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(10000); // wait for a 10 seconds
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
}//end of loop
What I want is the "SelectButton" on digital 3, is to bounce between the two menu items. ("Timer Off" and "Timer On")
If the "SelectButton" is pushed once it will set the cursor for increment for "Timer On" If pushed again it will set the cursor to change to the menu item (Timer Off) which will then be able to increment.
Ultimately these selections will set the values for this bit of code.
Thanks again for your help, I am new to the arduino and C++ but once I get past this I think I will be able to expand on it and further learn.
I am calling the printed "Timer On" and Timer Off" menu items. With the code that I posted if I hit the increment buttons it will show a number next to the printed "Timer Off" I want to use that number in my code to set the led time off for the amount of seconds set by the increment button. Then be able to push the select button again to set the number of seconds the timer should remain on.
#define factor 1000
const byte incrementButton = 5;
const byte decrementButton = 6;
const byte SelectButton = 3;
//Global variables
boolean incrementState = 0; //variable that will read the increment button (either HIGH or LOW)
boolean decrementState = 0; //variable that will read the decrement button (either HIGH or LOW)
boolean lastIncrementState = 0;
boolean lastDecrementState = 0;
boolean selectState = 0;
boolean lastSelectState = false, State = false, ON = true;
int led = 13;
unsigned long Ontime = 0, Offtime = 0;
byte TimeOn = 1, TimeOff = 1;
lcd.setCursor(1,0);
lcd.setCursor(1,1); //Set the cursor at row 2 to print next line
lcd.setCursor(0,1);
lcd.print(">");
}//end of setup
if(selectState != lastSelectState) // lastSelectState will need to be declaired boolean too at the top of your code.
if(selectState == HIGH)
if(State)
lcd.setCursor(0,0);
lcd.print(">");
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,0);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(">");
lastSelectState = selectState;
if(incrementState == HIGH)//increment button is pressed
if(State == HIGH)
TimeOn++;
TimeOff++;
if(decrementState == HIGH)//decrement button is pressed
if(State == HIGH)
TimeOn--;
TimeOff--;
lcd.setCursor(10, 0);
lcd.print(TimeOn); //print it on serial monitor
lcd.setCursor(10, 1);
lcd.print(TimeOff); //print it on serial monitor
LEDState();
}//end of loop
void LEDState()
if(millis() - Ontime > (TimeOn * factor) && ON == true) // ON in this case looks to see if the LED itself is on. So before this IF statement is true, the LED is on
Offtime = millis(); // Notice it does not say Ontime, but instead it says Offtime. This is because when the
// LED is OFF, we want to start the timer to turn it back ON.
digitalWrite(led, LOW); // turn off LED
ON = false;
if(millis() - Offtime > (TimeOff * factor) && ON == false) // LED is currently off, now keep counting to turn it on.
Ontime = millis();
digitalWrite(led, HIGH); // turn on LED
ON = true;
