Hi. I'm building a double footswitch with led to extend to a midi controller where switch timing is vital. I've taken the basics of this code from a working project, but for some reason it doesn't "behave". The led works (as in the "intro" code and I've tested both buttons using the arduino example code, but the switches don't operate the led on/off as I'd hoped. For the simplest test, I wanted one switch to light the led, other other to switch it off.
Probably something obvious, but it's giving me headaches!
// orange 2 way box midi controller sending CC and note midi data
#define SWITCH1 2
#define SWITCH2 3
#define SWITCHES 2 // how many switches?
int switches[SWITCHES] = { SWITCH1, SWITCH2 };
int switchState[SWITCHES] = { LOW, LOW }; // Initial state of switch
int currentSwitch = 0;
const int led1 = 7; // led 1
// int scene = 1;
unsigned long SwitchMillis = 0; // when button was released
unsigned long DebounceMillis = 20; //
unsigned long CurrentMillis = 0;
pinMode(led1, OUTPUT); // setup LED 1
for (currentSwitch = 0; currentSwitch < SWITCHES; currentSwitch++) {
pinMode(switches[currentSwitch], INPUT); // Set pin for switch
digitalWrite(switches[currentSwitch], HIGH); // Turn on internal pullup
for (int i = 0; i < 5; i++) // show "welcome" message
digitalWrite(led1, HIGH);
delay(100);
digitalWrite(led1, LOW);
delay(100);
} // end setup
CurrentMillis = millis(); // get the time at the start of this loop()
if (CurrentMillis - SwitchMillis >= DebounceMillis) //is it time to check the switches?
SwitchMillis = millis(); //re-initilize Timer
if ((digitalRead(switches[currentSwitch]) != switchState[currentSwitch]) && (switchState[currentSwitch] == HIGH)) {
switch (currentSwitch) {
case 0:
case 1:
} // end case
} // end current switch
} // end if changed
switchState[currentSwitch] = digitalRead(switches[currentSwitch]);
} // go thru switches
} // end loop
#define SWITCH1 2
#define SWITCH2 3
// int scene = 1;
delay(100);
delay(100);
} // end setup
// if ((digitalRead(switches[currentSwitch]) != switchState[currentSwitch]) && (switchState[currentSwitch] == HIGH)) {
// read current state
uint8_t stateNew = digitalRead(switches[currentSwitch]);
// dedect state change
if (switchState[currentSwitch] != stateNew)
// save new state
switchState[currentSwitch] = stateNew;
case 0:
case 1:
} // end case
} // end if changed
// switchState[currentSwitch] = digitalRead(switches[currentSwitch]);
} // end loop
I have added a correct state change detection, not tested.
Right now you have a for loop that reads one switch and then the other. The code to turn on or off the led is in that for loop such that either switch has complete control. The part that turns the led on or off should check currentSwitch to see which switch has been flipped.
Or even better, let the switch reading part of the code just decide which switch is in which state and set up a couple of variables to track that. Then move the part that lights leds to a separate section and write logic based only on whether those switches are flipped or not.
