button monitor and action at once
Attached code's purpose want to let the sketch keep a beep intermittently, and monitor the button if pressed do some thing /three(); / at once. But the test shown the action happened till the delay period finished.
Need help how to let the action happen at once when button pressed.
Thanks.
int buzz = 2; // Buzzer Pin
int input = 0;
const int buttonPin = A0;
int buttonState = 0;         // variable for reading the pushbutton status
int j = 3; // number
int k = 12; // number
int period = 10000;
unsigned long time_now = 0;
  for (int i = 2; i <= 13; i++)
    pinMode(i, OUTPUT);
    digitalWrite(i, LOW);
  pinMode(A0, INPUT);
  digitalWrite(A0, HIGH);
// the loop routine runs over and over again forever:
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == LOW) {
    three();  //// twoA better
    tone(2, 250, 20);
     delay(4000);
void three() {              //This function produces the 3rd siren(AMBULANCE) sound with led transition.
  tone(buzz, 440, 200);
  delay(300);
  for (int i = 3; i <= 6; i++)
    digitalWrite(i, HIGH);
  noTone(buzz);
  tone(buzz, 494, 500);
  delay(300);
  for (int i = 3; i <= 6; i++) {
    digitalWrite(i + 6, HIGH);
  noTone(buzz);
  tone(buzz, 523, 300);
  delay(200);
  digitalWrite(7, HIGH);
  delay(50);
  digitalWrite(8, HIGH);
  delay(50);
  noTone(buzz);
Don't use delay.
Do timing using the techniques shown in the BlinkWithoutDelay example and you need to program using a Finite State Machine structure to work around the do/wait/do/wait elements of the code.
I recently wrote this blog post that may help you Finite State Machine Programming Basics – Part 1 – Arduino++, but there is lots out there on what to do.
Others may chip in with their own examples.
marco_c:
Don't use delay.
Thank you.
I checked the BlinkWithoutDelay example which is suitable my case, but it's led ON and OFF at same period, how can modify it ON for 1 second and OFF for 5 seconds?
Keep the delay target time in a variable. When the LED is turned on, set the variable to 1 second. When the LED is turned off, set the variable to 5 seconds.
if you are looking at the blink without delay example. everything in the bracket happens once every second. if you want to have something change every 5 seconds use a timer.
int timer;
unsigned long last;
if (millis() - last >=1000) {
  last = millis();
 timer++;
if(timer==5){timer=0;}
    // if the LED is off turn it on and vice-versa:
    if (timer==0){
     digitalWrite(ledPin,HIGH);
     digitalWrite(ledPin, LOW);
