button section doesn't want to work
#include <IRremote.h>
const int buttonPin = 12;
const int led = 13;
IRsend ir;
char dato;
unsigned int pwrTv[68] = {4550,4300,600,1550,600,1550,600,1550,600,450,600,450,650,450,600,500,550,500,600,1550,600,1600,600,1550,600,500,600,450,550,500,600,450,600,500,600,450,600,1550,600,500,600,450,600,500,600,450,600,500,600,450,600,1550,650,450,600,1550,600,1550,600,1550,600,1550,600,1550,600,1550,600};
unsigned int Signal_0_0[] = {4550,4400,600,1650,550,1650,600,1650,550,550,600,500,600,550,550,550,600,500,600,1650,600,1600,600,1650,550,550,600,500,600,550,600,500,600,500,650,450,650,1600,600,500,650,450,650,500,600,500,600,500,600,550,600,1600,600,500,650,1600,650,1550,650,1600,650,1550,650,1600,650,1600,600};
unsigned int  rawData[67] = {4500,4500, 500,1700, 550,1700, 500,1700, 550,600, 500,600, 500,550, 600,550, 550,600, 500,1650, 550,1750, 500,1700, 500,600, 550,600, 500,600, 500,600, 550,550, 550,600, 500,1700, 550,600, 500,600, 500,550, 550,600, 550,600, 500,550, 550,1700, 550,600, 500,1650, 550,1750, 500,1650, 550,1750, 500,1700, 500,1750, 500};
int buttonState = 0;         // variable for reading the pushbutton status
  pinMode(buttonPin, INPUT);
  pinMode(buttonPin, OUTPUT);
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
if (buttonState == HIGH);
    ir.sendRaw(rawData,67,38);
else  {
    digitalWrite(ledPin, HIGH);
    delay(100);
    digitalWrite(ledPin, LOW);
can you guys help me
i'm using an arduino uno
here is the error:
/tmp/425907993/on_off_tv_remote_benede/on_off_tv_remote_benede.ino:27:1: error: expected unqualified-id before 'if'
/tmp/425907993/on_off_tv_remote_benede/on_off_tv_remote_benede.ino:28:3: error: expected unqualified-id before '{' token
/tmp/425907993/on_off_tv_remote_benede/on_off_tv_remote_benede.ino:32:1: error: expected unqualified-id before 'else'
else {
exit status 1
} // ***** this is the end of loop()
if (buttonState == HIGH); // ******* this is outside any function
Steve
thx gona try and fix it
const int ledPIN = 13;
IRsend ir;
char dato;
    delay(100);
still not working
/tmp/186395833/on_off_tv_remote_benede/on_off_tv_remote_benede.ino: In function 'void loop()':
/tmp/186395833/on_off_tv_remote_benede/on_off_tv_remote_benede.ino:33:3: error: 'else' without a previous 'if'
/tmp/186395833/on_off_tv_remote_benede/on_off_tv_remote_benede.ino:35:18: error: 'ledPin' was not declared in this scope
exit status 1
changed the code a bit
int buttonPin = 8;
int ledPin = 13;
IRsend ir;
char dato;
  pinMode(ledPin, OUTPUT);
    delay(100);
  if (buttonState == LOW);
    delay(100);
    delay(3000);
i can upload it finaly but the button section doesn't wan't to work
(deleted)
(deleted)
