Button-sketch error. "expected primary-expression before ','token
int buttonPin= 7; //the number of the pushbutton pinPreformatted text
int buttonState=0; //variable for reading the pushbutton statusPreformatted text
int ledPin=12;
int ledState=0; //variable for reading the LED statusPreformatted text
void setup() Preformatted text
{ Preformatted text
pinMode(12, OUTPUT); // initialise the ledPin as an output: Preformatted text
pinMode(buttonPin, INPUT); // initialise the buttonPin as an input: Preformatted text
} Preformatted text
void loop() Preformatted text
{ Preformatted text
buttonState = digitalRead(buttonPin); // read the state of the pushbutton value: Preformatted text
ledState = digitalRead(ledPin); //read the state of the LED valuePreformatted text
if (buttonState == LOW), (12State == LOW); // if the pushbutton and LED is on.Preformatted text
{Preformatted text
digitalWrite(); // do nothing if the buttonState is off and 12State is off: Preformatted text
} Preformatted text
if (buttonState ==HIGH), (12State == HIGH); // if buttonState is on and 12State is onPreformatted text
{ Preformatted text
digitalWrite(12, LOW); // turn LED off if the buttonState is on and 12State is on: Preformatted text
} Preformatted text
if (buttonState == LOW), (12State == HIGH); // if buttonState is off and 12State is onPreformatted text
{Preformatted text
digitalWrite();Preformatted text
}Preformatted text
if (buttonState == HIGH), (12State == LOW); // if buttonState is on and 12State is offPreformatted text
{digitalWrite(12, HIGH); //turn LED on if buttonState is on and LED is offPreformatted text
}Preformatted text
The error is in the third last line
This one?
Compare that one to say this one:
That's the 4th last by my count, but whatever, the one I pointed out is wrong anyway.
But try this for the one you want fixing:
if (buttonState == HIGH && 12State == LOW);
BUT also lose the ; on the end, since that's a premature ending of the "if". Then put the lines you want to run when the "if" is passed, in a pair of {}.
Can you fix the formatting of the code in original post.... What's all that "preformatted text" stuff? Very difficult to read. Code should look thus:
//foo
//bar
Please fix your code. It is unreadable.
Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
int ledPin=12;
if (buttonState == LOW && 12State == LOW);               //  if the pushbutton and LED is on.
if  (buttonState ==HIGH && 12State == HIGH);   // if buttonState is on and 12State is on
if (buttonState == LOW && 12State == HIGH);   // if buttonState is off and 12State is on
    digitalWrite();
if (buttonState == HIGH && 12State == LOW); // if buttonState is on and 12State is off
    digitalWrite(12, HIGH)     //turn LED on if buttonState is on and LED is off
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
C:\Users\Documents\Arduino\sketch_sketch_.ino: In function 'void loop()':
sketch_20:27: error: unable to find numeric literal operator 'operator""State'
sketch_22:16: error: too few arguments to function 'void digitalWrite(uint8_t, uint8_t)'
In file included from sketch\sketch_.ino.cpp:1:0:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Arduino.h:135:6: note: declared here
 void digitalWrite(uint8_t pin, uint8_t val);
sketch_:25:28: error: unable to find numeric literal operator 'operator""State'
sketch_:29:27: error: unable to find numeric literal operator 'operator""State'
sketch:31:18: error: too few arguments to function 'void digitalWrite(uint8_t, uint8_t)'
     digitalWrite();
sketch_:33:28: error: unable to find numeric literal operator 'operator""State'
sketch_:36:3: error: expected ';' before '}' token
exit status 1
option enabled in File -> Preferences.
You still have all those ";" on the end of the "if"s so even if the test passes, what follows doesn't run.
And sorry I misled you: you only have to use {} if there's more than one line to run if the test passes. It's ok to have only one line in the {} though, like you have it now, and I often do that as a matter of course. Just a bit of extra typing, but if you then edit the code and add another line, the {} are already there and won't get forgotten.
And you still have the "empty" digitalWrite.
It doesn't like "12State" which you didn't declare. Are those supposed to be "ledState" maybe?
A valid variable name cannot begin with a number.
But they didn't try to declare that anyway. I think it should be ledState, which is declared? Something's hinky with some cutting and pasting, methinks.
(Anyway I'm off for my morning run and then some breakfast....)
Thanks! So if I want nothing to happen, what do I put in the empty brackets... Or do I just delete the line? (I was away in class so I have no idea what to do...)
C:\Users\Documents\Arduino\sketch_may24a\sketch_may24a.ino: In function 'void loop()':
sketch_may24a:22:16: error: too few arguments to function 'void digitalWrite(uint8_t, uint8_t)'
In file included from sketch\sketch_may24a.ino.cpp:1:0:
sketch_may24a:31:18: error: too few arguments to function 'void digitalWrite(uint8_t, uint8_t)'
     digitalWrite();
sketch_may24a:36:3: error: expected ';' before '}' token
exit status 1
int ledPin=12;
if (buttonState == LOW &&ledState == LOW)             //  if the pushbutton and LED is on.
if  (buttonState ==HIGH && ledState == HIGH)   // if buttonState is on and 12State is on
if (buttonState == LOW && ledState == HIGH)   // if buttonState is off and 12State is on
    digitalWrite();
if (buttonState == HIGH && ledState == LOW) // if buttonState is on and 12State is off
That's not "do nothing".
There's a massive clue in the error message
Your semicolon has gone walkies.
so I just put "uint8_t, uint8_t"....?
No, those are holders for the parts that are present in the digitalWrites that work. But generally if you don't want to do something, don't do anything. So leave that whole thing out.
That's a huge pity and I feel for you, whatever the reason for your absence was, but it's not going to work by you just throwing random stuff at the compiler and trying to fix it when it screams at you line by line.
Does the teacher give out notes or references for you to use for the class?
Did you find out from other students what they were given?
Tom... :smiley: :+1: :coffee: :australia:
I will try to ask the teacher in the next class
