When I run this and start up the terminal I see leftrightableftrightableftrightab . . . ad infinitum, even though I haven't pressed a button.
What mistake(s) did I make, please?
Ha, it's been about 2 years since I've messed with any MCUs and I made the same mistake about the power jumpers before. Of course it works now, but is there a modification I can make to have it register each push only once?
Thank you
Also I will look into using the internal pull-up. Guess I will have to check for LOW instead of HIGH.
Thanks again
Making a 16X32 led display with a many atari-style games as I can cram into 32K
I will share the progress in the correct area of the forum.
The change in state will work for the click buttons. I'm adding a joystick for movement. I imagine that will want continuous reporting like I currently have.
Any other tips or reading you can recommend?
Happy to follow forum guidelines. I contribute to many other programming forums, been programming for 34 years.
