The following sketch uses 2 buttons, one button is wired to pin 4 and the other to pin 5. Both buttons are wired to ground on the Arduino. The ISR is supposed to add 1 to volatile int counter when I press button connected to pin 4 and subtract 1 when I press button connected to pin 5. However, it does exactly the opposite: subtracts 1 to volatile int counter when I press button connected to pin 4 and adds 1 when I press button connected to pin 5. I checked my connections and they are as per above. Any clues why this may happen?? Thanks for any hints. AA. PD: there is bouncing and double interrupt trigger from press-release happening but for now I'm just trying to understand the reason(s) for the opposite behavior of the Interrupt Service Routine.
volatile int counter = 0;
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
PCICR = B00000100; // Enable PIN CHANGE interrupts on D port
PCMSK2 = B00110000; // Allow trigger PIN CHANGE interrupts on pins D4 and D5
cli(); // We pause the interrupts
Serial.print("The counter is now at: ");
Serial.println(counter);
sei(); // We reactivate the interrupts
delay(100);
ISR (PCINT2_vect) {
if (PIND & B00010000) {
counter++; // Subtracts when I press button connected to pin 4!!!!!!!!!!!!
if (PIND & B00100000) {
counter--; // Adds when I press button connected to pin 5!!!!!!!!!!!!
Also, keep in mind you are getting interrupts whenever the pin changes, both HIGH to LOW and LOW to HIGH. That is in addition to the pin bounce. It is going to be hard to predict how the counter will change.
OK. But you should rarely ever need to use interrupts directly since for most hardware there are libraries that handle them for you. Interrupts can be very tricky and should be reserved for very time critical operations and should be as short as possible.
Back to your problem specifically, you need to filter the pin change direction (relatively easy and I would increment on LOW->HIGH) and handle debounce (tricky using interrupts).
Is there some reason you are not using the Arduino API to setup and handle the interrupts? You can specify which pin direction you want to interrupt on then all you have to do is debounce.
volatile byte counter = B00000000 instead of volatile int counter = 0works a LOT better in terms of not bouncing all over the place when I press the buttons and adding/subtracting 1, but the ISR behavior remains the opposite as before. Strange.
It is because the input pullup pulls the pin high, so when you press the one button it goes low and triggers the interrupt. Then when the interrupt triggers, the pressed pin is low so it doesn’t add, while the unpressed pin is still high so it subtracts. Then on release the first pin goes high so it adds, and the other pin is still high so it counteracts.
And vice-versa for the other button.
The logic is very awkward—on release both pins are high, and the increment offsets the decrement. On press, only the unpressed button’s logic triggers.
if (PIND & PIND4) {
if (PIND & PIND5) {
Sorry for asking basic questions: Picked the right Arduino? Not any wires mixed up? If you run a 'normal' sketch where you poll the buttons, will they be correct?
