CAB-10646 6 core ribbon cable
I have some CAB-10646 ribbon cable and crimping connectors. I was wanting to use it for connections between PCBs to carry; 5V 2amp, GND, and other connections e.g. CLK etc. I don’t know what the mm2 rating for this cable is. The length of the cables will be quite short i.e. 5-6cm and possibly up to 20cm.
Would this cable be OK for this use?
andyh-1963:
The current capability of wire is based on the wire size and the type of insulation. Neither are given in the documentation I have found. What have you found?
So, I guess you will just have to test it.
Paul
I found that wires of 0.75mm2 would be sufficient for the power being sent through the wire, but I don't know what the value of the CAB-10646 wires are!
I will test it later on and see...
Well measure the diameter of the wire's conductor then!
area = diameter^2*pi/4
volume resistivity of copper is about 1.7e-8 ohm-m
resistance / unit length = resistivity / area
Use S.I. throughout.
Or just find a table of wire properties which has a diameter column and look it up, there are dozens out there...
