Thank you for these responses. Answering some questions here:
Yes, the motor start voltage of 1.04v is measured at the joystick, 70’ from the motors. Clearly, that needs to be measured at the motor. No doubt a voltage drop of some significance would be happening. Whatever voltage the motor starts at, however, is less important than the start speed, which is too fast, regardless of what actual voltage starts the motion.
The mosfet pulse idea is an interesting one. Presuming that it could be pulsed with a modulation rate that would be imperceptible and mimic continuous motion, that would mean that I could keep the existing motor and gear arrangement. The programming and hardware selection will take some research on this noobie’s end, but c'est la vie. It sounds like the processing could all take place on the remote end, sending pulsed DC down the same lines I am using now. You could be my new best friend, Paul!
CedarLakeInstruments, there is no issue with having a power supply at the motor site. The camera has to have electricity anyway, so it is available. No need to send high current over a distance, just the data from a joystick. Still unclear if the distance would be between the joystick and the Arduino, or between the Arduino and the motor controller(s).
How about this scenario. A box with the Arduino, a 12v power supply and a motor controller programmed to pulse a higher voltage to the motor all located at the camera position, being controlled by the existing remote joystick device which sends 0v to ±10v. Since the analog DC would be going to an analog input on the Arduino (which is presumably high impedance), there would be no appreciable voltage drop or current on those lines. It would be programmed to vary the width of the pulse and voltage to have extremely fine movement on the lowest voltage input, and full speed movement at the highest voltage input, ramping in between.
Thank you for helping me out with all this info. I clearly have a lot of learning to do. The first step, when I get a solid understanding that it CAN be done, I will order my first Arduino starter kit and dive into the tutorials online. This old dog is about to learn some new tricks, hopefully.
Sincerely,
rcarbaugh
