I've build a simple cable tester using Arduino. Everything works fine except one thing. I have a ground pin on my connector that is actually grounded to the metal enclosure. Unfortunately, it doesn't allow me to energize my diods, because current goes to the ground. Is it a way to work around it?
Connectors installed on both sides. I'm testing pins on cable to validate proper cable termination. Unfortunately, grounding on connector goes straight to the enclosure where it's gounded to common GND.
DO I understand that you are testing the cable while it is connected to the enclosure? We always tested cables by themselves and that worked for thousands of cables.
Only ground does not work properly. I believe that I found a way how to fix this connector. I will replace screw that hold the insert to non-conductive screw. It will separate the ground on connector from enclosure. For next box, I will look towards plastic enclosure.
