Added:
Updated signal names labels on most multi purpose pins.
Signal directions (Arrows) on D0/RX - D1/TX pins.
Updated:
Revision history table.
Readme.txt file
Added:
Center cross marks on board corner holes. Updated:
Library updated and tested for compatibility on Eagle 7.5.0.
Minor cosmetic changes on history table formatting.
Updated device physical dimensions on general specifications table.
As of today, after almost nine months available my library CadSoft EAGLE Arduino Nano V3.0 Module Library accounts for almost 600 downloads, I am very grateful for your support and ratification.
Thank you for taking the time to do this. I'm getting a strange dimension error with DRC that is pointing at the nano board and I'm not sure why. (I'm very new to Eagle). It looks like the crosshairs might be crowding their neighboring pins. Is this normal and can this error be ignored? Thanks.
Thanks for any help with the library.
Cheers,
FB
Hello FishBulb,
Sorry for my very late response.
I think you can ignore the error, I suspect it is a very tight parameter in your DRC.
The image inserted below corresponds to the module with all the layers activated, note the cross-hair is not touching any other part on the device.
