Calculate temperature and humidity for 15 minutes
I'm using this code
// Import required libraries
#include "WiFi.h"
#include <Adafruit_Sensor.h>
#include <DHT.h>
#define DHTPIN 27 // Digital pin connected to the DHT sensor
// Uncomment the type of sensor in use:
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE);
String readDHTTemperature() {
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
//float t = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return "--";
else {
Serial.println(t);
return String(t);
String readDHTHumidity() {
float h = dht.readHumidity();
if (isnan(h)) {
return "--";
else {
Serial.println(h);
return String(h);
void setup(){
// Serial port for debugging purposes
dht.begin();
readDHTHumidity();
readDHTTemperature();
void loop(){
to compute the humidity and temperature, now I'm asking how can calculate temperature and humidity for 15 minutes ?
Use millis() for the timing so as not to block the operation of the sketch
See Using millis() for timing. A beginners guide, Several things at the same time and the BlinkWithoutDelay example in the IDE
Probably better to post your code here, not on a site asking for cookie permissions which many people will not do.
Meantime, what does this actually mean?-
updated!
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
