Calculating heartbeat frequency using PPG method - Help needed!
Hi everyone, my first post. I have created a PPG circuit that detects variation in blood flow and outputs a square wave with each pulse ( square wave due to high gain and saturation of OP amp outputs).
I have been working on writing a code that detects the number of pulses and finding the frequency over 6 seconds, then i'll multiply by 10 for BPM. Here's my code so far:
int pin = 13;
int timecount = 0; // time between pulses
int sumtime = 0; // summation of all time between pulses
int currtime = 0; // current pulse time - found in interrupt
int pulsefreq = 0; // frequency of pulses
volatile int pulsecounter = 0; //counter incremented with every pulse detection
volatile int state = LOW; // initialise LED status as LOW
volatile int pulsetime = 0; // initialise time when a pulse occurs
  pinMode(pin, OUTPUT);
  attachInterrupt(0, pulse, RISING);
  digitalWrite(pin, state);
  //--Calculating time of pulses--//
  currtime = pulsetime; //previous / current time of pulse
  timecount = currtime-timecount; //finding time difference between pulses
  sumtime = timecount+sumtime; //summing all the time differences
  //else pcount = pcount;
  //----Finding frequency of pulses---//
  if (pulsecounter=6)
  pulsefreq = 6/sumtime;
  Serial.println(pulsefreq);
void pulse()
  state = !state;
  pulsetime = millis();//reading time at which pulse occurs
  pulsecounter=pulsecounter + 1;//increment pulseee counter
I've modified the interrupt example and comparing my code with the "Pulse Sensor" project - Pulse Sensor Amped : ID 1093 : $25.00 : Adafruit Industries, Unique & fun DIY electronics and kits.
But i don't yet fully understand the timer functions.
Any help will be much appreciated.
Thanks!
You should avoid using interrupts as far as possible, and they aren't necessary here. You can just read the state of the input and look for changes in the state.
Just counting the number of complete beats over a few seconds will give you a very poor resolution because you would be rounding down the first and last incomplete beats - you could do a lot better by recording the cumulative duration of all the beats you detected during those six seconds and then multiply the count by (60 seconds / cumulative duration).
There's absolutely nothing wrong with using interrupts. They are there to be used.
Some of the problems with your code:
  • millis() returns an unsigned long integer but you are treating it as just a 16-bit integer. This will not work once the Arduino has been running for more than 32767 milliseconds when the number will overflow the capacity of a signed 16-bit integer.
  • the code in loop() doesn't need to do anything until a pulse has been detected. Set a flag in the interrupt routine. In loop() don't do anything until the flag is set.
  • if(pulsecounter=6) will set pulsecounter to 6 and always execute the conditional statement. You should use if(pulsecounter == 6)
  • pulsefreq = 6/sumtime; This will always produce zero because it is an integer division. It is also the wrong calculation.
Pete
el_supremo:
Nothing wrong with using interrupts where necessary, but using interrupts introduces extra design issues which are best avoided unless there is a compelling reason to use them. For example, you haven't mentioned (yet) that access to multi-byte variables is not atomic so the accesses to those volatile variables in the main context isn't safe. I don't think there are any race conditions in this code but it took me a while to come to that conclusion and I doubt the OP looked for that sort of problem.
There is no compelling reason to use interrupts here and the sketch would be much simpler without them.
Thanks for the reply PeterH
is something like this what you mean?:
int LED = 13; //LED to blink when pulsing
int din = 2; // digital pin 2 to read 0V or 5V
int check; // checks status of digital pin 2
int pulsecount = 0; //number of pulses (highs) seen on the digital pin
unsigned long int timecount = 0;//cumulative time of total pulses
unsigned long int freq=0;
  pinMode(LED, OUTPUT);
  pinMode(din,INPUT);
  check = digitalRead(din);
  if (check = 1023)
  digitalWrite(LED, HIGH);
  timecount = millis() + timecount;
  pulsecount = pulsecount +1;
  if (pulsecount = 6)
  freq = 6/ timecount;
  digitalWrite(LED,LOW);
  pulsecount = 0;
  Serial.println(freq);
it gives me a read of a very large number then goes to 0 and holds till reset
Thanks
willing2learn:
I'm afraid there are so many typos in that code that there's no chance of it doing anything useful. You really need to focus on the difference between = assignment and == comparison operators, and using { and } after if/else statements to show which statements are controlled by the if/else. Also note that digitalRead() returns either HIGH or LOW, not an integer that could ever equal 1023.
The StateChangeDetection example sketch shows how to read the input and detect when it has changed. When it has changed you need to execute a bit of code which does the following:
If this is the first pulse detected, record the value of millis() as the time of the first pulse and set the number of beats to zero. Otherwise record the value of millis() as the time of the last pulse and increment the number of beats.
Use the technique demonstrated in Blink Without Delay to determine when the elapsed time exceeds six seconds. When that happens, subtract the time of the first pulse from the time of the last pulse to get the duration of the whole beats detected. You already have a count of the number of whole beats. Now it's simple arithmetic to calculate the number of beats per minute.
Thanks for the reply el_supremo!
i made some changes to the code - adding the flag and correcting the declarations:
int pin = 13;
int long timecount = 0; // time between pulses
int long sumtime = 0; // summation of all time between pulses
unsigned long int currtime = 0; // current pulse time - found in interrupt
int long pulsefreq = 0; // frequency of pulses
volatile unsigned long int pulsetime = 0; // initialise time when a pulse occurs
int flag; //check if pulse detected
  if (flag == 1) // go through loop if flag is set
  if (pulsecounter==6)
     pulsefreq = (360/sumtime); // 60 *6/sumtime
     flag = 0; // set flag low till next peak detected
     pulsecounter =0; // reset the counter
  if (flag == 0); // bypass the loop if flag is still low
    flag=0;
void pulse()
  state = !state;
  pulsecounter=pulsecounter + 1;//increment pulse counter
  flag=1;
I have been unable to figure out why the pulsefreq calculation was wrong?
Thanks!
Hi PeterH, i have made changes to the code:
int check; // checks current status of digital pin 2
int prevcheck;// previous check status
int BPM = 0; //beats perminute = counter value * 10
unsigned long firstpulse =0; //time of first pulse
unsigned long timecount = 0;//cumulative time of total pulses
unsigned long latestpulse=0;
unsigned long interval = 6000; //setting 6 seconds as max read time
  pinMode(din,INPUT);
  if (check != prevcheck ) // comparing current state to previous state
    if (check == HIGH)
      if (pulsecount ==1); // if this is the first count
        firstpulse = millis(); // recording time of first pulse
        //pulsecount = 0; //assigning 0 to counter
         pulsecount = pulsecount +1; // increment pulse counter when detected
         //timecount = millis() + firstpulse + timecount; //sumation of all pulse periods
         latestpulse = millis(); // reading latest pulse time
      if (latestpulse - firstpulse > interval) //checking if 6 seconds has elapsed
        BPM = pulsecount * 10;
        Serial.println(BPM);
Though the LED blinks, there is nothing displayed on the serial print screen
Thanks
willing2learn:
On line 31 you have a spurious semicolon at the end of the line which renders the whole line ineffective.I think you should also be comparing against zero to find whether it's the initial pulse. You also seem to have spurious parenthesis on lines 38 and 42 which could be deleted.
Hey PeterH, I'm stuck right now :~
Wouldn't it simplify things with the interrupt - then the processor would exactly when i want the loops to run (at rising edge)?. At the moment it only detects any change - therefore keeping the LED on.
The rest of the code doesn't run as expected even with the changes:
  pinMode(din,INPUT);
    if (check == HIGH)
      if (pulsecount == 0 ) // if this is the first count
        pulsecount = 0; // counter restarted
The printed value does change when the time interval is reached, but only displays zeroes or 10s at each second after
Thanks
Interrupts, as PeterH mentioned, are not necessary here. Furthermore, they bring new hazards to trip you up and can be hard to debug. I'd suggest, looking at the problems you're having, that you should leave them alone until you've got a bit more experience.
The reason that the LED stays on, sadly, is simply that you never do anything to turn it off.
Another omission that's causing you trouble is that you're trying to use prevcheck to detect a change in state on the digital pin. prevcheck is never touched, so it retains its original zero value throughout the sketch, which isn't helping.
Both of these should be fairly easy to fix.
Hey Wildbill, thanks for the reply
I have made changes to the code. The LED flashes in time with the heartbeat. But now nothing is printed on the screen monitor:
  pinMode(din,INPUT);
 // if (check != prevcheck ) // comparing current state to previous state
    if (check == LOW)
      digitalWrite(LED, LOW);
     // check = prevcheck;
    if (check == HIGH)
        pulsecount = pulsecount +1; //increment the counter
      if (pulsecount >=1 )
        pulsecount = pulsecount + 1; // increment pulse counter when detected
        latestpulse = millis(); // recording latest pulse time
        BPM = pulsecount;
        Serial.println(BPM); //display the number of counts over 6 seconds
        //pulsecount = 0; // counter restarted
        firstpulse = 0; // restart for time of new first-pulse read
        latestpulse = 0; // restart for new time readings
        //delay(1000);
Thanks
You need your prevcheck logic so that you only increment pulsecount when you detect a change. As you have it, I suspect that pulsecount overflows within the six seconds and allows a reset of first pulse so that the six second interval is never achieved.
Hi Wildbill, as soon as i reintroduce prevcheck, the LED is stuck high, with no display as well.
Thanks
I should have been more clear: don't bring back all the prevcheck stuff you had. Just put this as the last line in loop:
check = prevcheck;
Thanks Wildbill, getting closer!
The LEDs flicker now and the printed lines are like:
5965
2852
3460
1240
5687
4362
3984
7007
6946
6566
6641
2015
The lines are printed about every 6 seconds, so that works.
I'm guessing the processor is running through the loop several times faster than i want it - is this anything to do with the 9600 baud rate?
Thanks
oops. Should have been
prevcheck = check;
Now the LED flashes correctly - with the heartbeat, but there is nothing printed. I've also tried going back, but still nothing is printed. Here's the code now:
  pinMode(din,INPUT);
  //if (check != prevcheck ) // comparing current state to previous state
    if (check == LOW)
      //prevcheck == LOW;
    if (check == HIGH)
      //prevcheck == HIGH; //storing current state of input pin
      check == LOW; //reset the check
        BPM = pulsecount;
        //delay(100);
      prevcheck = check;
Thanks
ok. try this:
if(check != prevcheck)
  if (check == LOW)
  if (check == HIGH)
  BPM = pulsecount;
prevcheck = check;
