I develop many projects using arduino but power supply is always one big question for me. I am always afraid to put a large amount of current in my arduino and blow his regulators. I would like to know how you guys manage to calculate the ideal power supply, and how to provide that energy to all elements involving the project.
For ex, I am current working on a Target Shooting with LDR. There are 6 LDR each with his respective servo, every time one random pair of servo/LDR is selected to be aimed with a laser, when it hits other pair is selected. I also have two 4 digit BCD display that show time and score for the player. All servos are connected in a protoboard and the 5V arduino output is supplying their power.
So the project have:
1x Arduino Mega
6x Servos
7x LDR(6 for target, and 1 to start the game)
2x 4 digid BCD display
For now I am using 2 power supplies at the same time: one Android charger in the USB port of the Arduino(5V-2A) and one standard 5x2.5 power supply(12V-1A). The problem is one of the servos always have trouble to go UP, as if there is no enough current to make him move.
So what do you guys think? I need to change to a 3.5/4A power supply? Should I just put a exclusive supply for all the servos?
Also, any general tip on power supplies for Arduino projects?
Thanks!(Also, sorry for any english mistake, not my first language)
Very nice description and write up. We have something similar to this at a local sporting store called Outdoor world. It makes shooting sounds and makes bell sounds also when it registers a hit.
Please include even more detail. Servos, wiring diagram or schematics, pictures, codes... It is hard to respond to a specific problem you are having without enough information...
A power supply will only supply the amount of current that the load needs.
A 5V 2A supply will output 5V at any current below 2A.
A 12V 10A supply will output 12V at any current up to 10A.
If you are afraid of damaging a controller due to over current, then I suggest if you are developing many projects, you purchase a power supply with variable voltage and variable current limit.
Although somewhat expensive it will be well worth the effort and addition to your workbench.
Tom.....
