So how much impact does this have on speed? Is there a simple way to test it or a simple rule of thumb?
I tried making a simple sketch where two variables are declared as ints and multiplied to form a third variable as int and then switch a pin high/low to see the loop period on a scope. Then I changed the variables from int to float and got the same period. I guess the "loop time" in arduino is the limiting factor in this case?
If the numbers are all constants, the compiler may be optimizing out the math.
Floats should be significantly slower.
Also, tighten the loop, and don't use digitalWrite() to twiddle the pin, because digitalWrite() is slow, it's like 50 clock cycles or something.
Pick a pin to output the signal on, set it as output, and look at pinout charts. You'll see it marked like PA1 or PC2 or whatever. To toggle the current state of that pin:
PINA=(1<<1);
or
PINC=(1<<2);
and so on. Much, much faster.
ie
pinMode(A2,OUTPUT);
while (1){
float1+=float3; //gotta change it's value so it doesn't get optimized out.
PINC=(1<<2);
//code will never get here since there's an infinite loop in setup()
Something like that will probably work better - that was just off the top of my head.
Note that I think someone actually did more rigorous performance calculations here and posted them somewhere.
if you test performance you should declare the ints and/or the floats volatile, so the compiler won't optimize them. IN sketch below the multiplication is tested for 3 datatypes in a loop of 1000. Note that the loop overhead is same for all 3 loops.
// FILE: .ino
// AUTHOR: Rob Tillaart
// VERSION: 0.1.00
// PURPOSE: demo
// DATE: 2016=01-13
// URL: http://forum.arduino.cc/index.php?topic=371813.0
// Released to the public domain
uint32_t start;
uint32_t stop;
volatile int x = 3, y = 4, z;
volatile long k = 3, l = 4, m;
volatile float p = 3, q = 4, r;
Serial.print("Start ");
Serial.println(__FILE__);
start = micros();
for (int i = 0; i < 1000; i++)
z = y * x;
stop = micros();
Serial.println(stop - start);
start = micros();
m = k * m;
stop = micros();
start = micros();
r = p * q;
stop = micros();
Note that floating point divides may be very close or even faster than 32bit integer ("long") divides, because code has to essentially perform the same divide algorithm on only 24 bits instead of 32.
westfw:
update sketch,
added byte in multiply
added divide for 4 datatypes.
added addition for 4 datatypes (subtraction is same)
// FILE: mulCompare.ino
// VERSION: 0.1.01
// PURPOSE: demo
// DATE: 2016-01-13
uint32_t start;
uint32_t stop;
volatile byte a = 3, b = 4, c;
Serial.println("multiply compare, time per 1000 micros");
start = micros();
c = a * b;
stop = micros();
start = micros();
z = y * x;
stop = micros();
start = micros();
m = k * m;
stop = micros();
start = micros();
r = p * q;
stop = micros();
Serial.println("divide compare, time per 1000 micros");
start = micros();
c = a / b;
stop = micros();
start = micros();
z = y / x;
stop = micros();
start = micros();
m = k / m;
stop = micros();
start = micros();
r = p / q;
stop = micros();
Serial.println("add compare, time per 1000 micros");
start = micros();
c = a + b;
stop = micros();
start = micros();
z = y + x;
stop = micros();
start = micros();
m = k + m;
stop = micros();
start = micros();
r = p + q;
stop = micros();
output (byte int long float)
976
1804
6568
10160
5968
14628
40888
29408
768
1256
2156
7896
Just to check I ran this on a Teensy 3.2 at 72MHz. Here are the results:
230
181
167
601
170
252
167
515
143
169
154
1045
And the same on a Arduino Uno:
968
1812
6632
10160
5960
14628
40888
29408
768
1252
2156
7896
Wow, I had noe idea that data types had such a huge impact on speed. Same with the type of operation performed. Dividing also had a huge cost compared to addidion/subtraction.
Dande80:
230
181
167
601
170
252
167
515
143
169
154
1045
968
1812
6632
10160
5960
14628
40888
29408
768
1252
2156
7896
Damn ist that ARM M4 chip fast.
How come float is even faster sometimes than the other types on the ARM?
Lars81:
float = 23 bit mantisse == 3 bytes and 8 bit exponent
long = 32 bit mantisse == 4 bytes
for division the exponents are subtracted which is very fast for 8 bit, takes < 5% of time.
so in effect you are comparing a 3 byte division with a 4 byte division .
From this reasoning the time for a long should be approx 4/3 x time float
looking at the number for UNO we see
float = ~30 uSec and long ~40 uSec
Note that other numbers might give different results.
Many ARMs have some sort of code memory caching that can cause the same code to take different times just because of how it happens to be positions in memory. It can be very difficult to figure out a cycle count, even looking at the assembly code
I'd like to know why the double and float timings are so close - I'd expect doubles to be about half the speed of float...
The DUE main uc is a 32-bit uc (SAM3X8e), therefore all access are optimized for 32-bit variables.
Operations shorter than 32bit can require extra "extend" instructions, depending on operation and how good the compiler is - I've seen articles stressing that 32bit math can be faster than 8bit math on an ARM. But I don't think this explains why 16bit math would be faster than 8bit math...
