Calibration in EEProm
Hello,
i´m using a forcesensor and would like to execute a one-Time calibration. That calibration value should be written in the eeprom and be used as a reference every time the arduino is started.
My problem is, that the calibration is done every time i start the arduino even with the "calPin" pulled to low.
#include <EEPROM.h>
int calPin = 2;
int sensorPin = A2;
int ledPin = 3; //PIN 0 für Tiny
int sensorValue = 0;        // Wert der vom Sensor gelesen wird
int calValue = 0;
  pinMode(sensorPin, INPUT);
  pinMode(ledPin, OUTPUT);
  analogWrite(ledPin, 0); // LED aus
  if (calPin = HIGH){
   calValue = analogRead(sensorPin);  // Sensor lesen
   EEPROMWriteInt(1, calValue);
  sensorValue = analogRead(sensorPin);  // Sensor lesen
    if (sensorValue >= EEPROMReadInt(1)){     // Wenn Voll: LED an
   analogWrite(ledPin, 70);
    if (sensorValue <= EEPROMReadInt(1) - 50){     // Wenn Leer: LED aus
 delay(10);  // 10 Millisekunden warten um den ADC zu Nullen
Serial.print("sensorValue: ");
 Serial.println(sensorValue);
 Serial.print("EEProm: ");
 Serial.println(EEPROMReadInt(1));
void EEPROMWriteInt(int address, int value)
  byte two = (value & 0xFF);
  byte one = ((value >> 8) & 0xFF);
  EEPROM.update(address, two);
  EEPROM.update(address + 1, one);
int EEPROMReadInt(int address)
  long two = EEPROM.read(address);
  long one = EEPROM.read(address + 1);
  return ((two << 0) & 0xFFFFFF) + ((one << 8) & 0xFFFFFFFF);
Should be
    if (calPin == HIGH){
Auch! Thank you!
That changed something but it´s not working right. Now i get everytime the same eeprom value in my serialmonitor reading but i con not update the value pulling pin 2 HIGH.
Why is the eeprom not updating?
Thanks!
You never actually read calPin.
This is not the way to read a pin:
All that's doing is comparing the value of calPin (which is defined as 2) to HIGH (which is defined as 1). To read a pin, you need to use digitalRead(). Please study this documentation:
and this tutorial:
@pert
Thank you so much!
Now it works like it should!
Thats the version that works:
#include <EEPROM.h>
int calPin = 2;
int sensorPin = A2;
int calValue = 0;
  pinMode(calPin, INPUT);
 int calState = digitalRead(calPin);
  if (calState == HIGH){
   EEPROMWriteInt(10, calValue);
    if (sensorValue >= EEPROMReadInt(10)){     // Wenn Voll: LED an - Wert für großen Sensor
    if (sensorValue <= EEPROMReadInt(10) - 50){     // Wenn Leer: LED aus - Wert für großen Sensor
 Serial.println(EEPROMReadInt(10));
