Camera for drone
Im not sure if this is off topic, but please read
I got a drone whilst overseas in Germany. It flies well but the camera was factory broken. So back in Perth, i got in contact and and they sent me a new camera. It doesnt work either, so i looked inside. Maybe someone can get some info on the Ic Chipset (All it says on the chip is:15140 D14C123-644756)
And maybe help me as to why the camera doesn't even switch on. Oddly behind the sd card socket there is a spot where i reckon a usb jack of sorts is meant to go. Please Help.
Thanks and those are the images above :smiley:
OK, let's see them!
Those pictures do not seem to have much detail.
Ok I cant access an other camera right now, but i can explain what parts are
Did you read the instruction manual of that camera.?
Doesn't come with one sadly, it was shipped as is.
I do not recognise that unit BUT.
A member of my local club did get a camera from somewhere last year which turned out to have the red lead as negative and the black lead as positive.
It may have been white/black but cannot remember.
Thanks, im going splice the cable and add header, and maybe it will turn out to work. I also realised something shocking aswell:It seems some polarity has been changed, hence,
From drone: RED --> Blue
Black --> Black
White --> RED
Maybe thats the problem
did it work ??
Havent had time, but will definatly try
