Camera Robot Issue-CTC 101 kit issue
Hello,
Our class has been working on the Camera Robot Project in the CTC 101 kit. We followed all the troubleshooting streps and found that the breadboard is not transferring power to servos. Has anyone had a similar issue and if so, what did you do to fix it?
Thanks
Breadboards are intended for low power logic circuits, and can't be used for servo or motor power. The tracks will burn.
You need to solder the power connections, or use screw terminals. Make sure there is a common ground with the Arduino.
We used the education shield provided with the kit as well. I don't know if this changes anything.
