sorry if this is a noob question but when it comes to electronics I want to be sure so I don't damage anything. I'm following this circuit diagram below with arduino uno r3, nema 17, a4988 driver. My power supply to motor is going to be a 12V 5A dc wall adapter that I connect to the female adapter. And I was going to connect my uno to my laptop via usb. Is that correct?
Yea I was gonna do that, I was wondering is there like a specific screw driver I need for the potentiometer on the driver or does any arbitrary on the fits work. I hope I don't shock myself when using the multimeter lol
Hello, so I'm a little confused here, I read online that roughly 1 Amp is the breadboards limit. So how can I connect a 12V 5A power supply to it? I'm also looking to control 3 1amp nema17 so I probably need a larger power supply in the future so I need to know how much juice I can input into the breadboard
both the encoder and a498 driver need to be connected to arduino's 5 volt and gnd. So I can connect the arduino's 5v and gnd to a breadboard positive and negative rails, then connect the driver and encoder to those rails for the 5 volt and gnd connection right? Also what software can I use to create these circuits?
Yes, it is OK to use a breadboard for 5V power distribution.
However breadboards are not designed for motor currents, so make direct connections from the motor and motor power supply to the driver.
If you mean a circuit diagram to upload to a post, a photo of a pencil and paper drawing is fine, as long as pins, parts and connections are clearly labeled. Otherwise, please explain what you mean by "create these circuits".
tinkercad doesn't have a a498 driver or a encoder so I just used a integrated chip and dc motor with encoder to explain what I meant. Again I just wanted to confirm before hooking it up that I can connect the arduino's 5 volt and ground to the rails, then connect the encoder and driver to those rails for their respective 5volt and ground pin.
