Hi guys, I want to know if i can control a 12V 30A Automotive Relay using a arduino directly?
Or do i have to partner it with some components?
I am not using the PWM port and prefer using a regular port that will On/Off the Relay. Is it possible to control the relay directly with out doing some damages to my Arduino? Pls help me
CrossRoads:
You'll need a transistor to sink current thru the relay coil to turn it on, and a diode to dissipate coil generated current when you turn it off.
Sir can you give me whats components should i provide to be able to operate a 12V 30A automotive relay? Can you also give me instruction how to use it?
bluejets:
First step is to look up the specs on the relay / or measure the coil resistance to work out what current the coil will draw when connected to 12V.
