Can a stepper motor go in reverse
How would I change this code to make the stepper motor go in reverse?
#include <Stepper.h>
int in1Pin = 8;
int in2Pin = 9;
int in3Pin = 10;
int in4Pin = 11;
Stepper motor(512, in1Pin, in2Pin, in3Pin, in4Pin);
pinMode(in1Pin, OUTPUT);
pinMode(in2Pin, OUTPUT);
pinMode(in3Pin, OUTPUT);
pinMode(in4Pin, OUTPUT);
// this line is for Leonardo's, it delays the serial interface
// until the terminal window is opened
while (!Serial);
motor.setSpeed(20);
if (Serial.available())
int steps = Serial.parseInt();
motor.step(steps);
Basically, you would have to set steps to a negative number. But I'm sure someone will be along to give you a more thourough explanation.
Hi, Always start with the DOCUMENTATION...
See: Stepper - Arduino Reference
You would find:
steps: the number of steps to turn the motor - positive to turn one direction, negative to turn the other (int)
Serial.parseInt() can parse negative numbers. Just type in a negative number.
