hi , i have this code it is Spectrometer i need to Simulation with Proteus , how connected LCD with Arduino?
thanks
spectro.ino (9.08 KB)
thanks
I do not understand the question, can you explain it in more detail?
thank you,
First you simulate correct at the Plug ,As the pictures ,Operating when the problem does not appear any action code.
I need to simulate my code with Proteus ( ISIS ) like pictures,
i am sorry my English is not good so much . but I understand
you can use google translate to help you. It might be easier to formulate the problem in your native language. Give it a try !
Your simulation application ISIS shows the wrong LCD on the 2 pictures.
That is a LCD with a parallel interface.
You need to find a LCD with a serial interface, or design it yourself. I assume that is possible in ISIS.
i know i using google translet , do you see my code ? i want my code running good like Image Untitled2.png
but i dont know my connect is Mis or true?
