#include <SoftwareSerial.h>
#include <TinyGPS++.h>
// Create SoftwareSerial connections
SoftwareSerial gpsSerial(4, 3); // RX, TX for GPS
SoftwareSerial gsmSerial(7, 8); // RX, TX for GSM
TinyGPSPlus gps;
Serial.begin(9600); // Serial monitor for debugging
gpsSerial.begin(9600); // GPS module baud rate
gsmSerial.begin(9600); // GSM module baud rate
// Initialize GSM module
Serial.println("Initializing GSM module...");
gsmSerial.println("AT+CMGF=1"); // Set SMS text mode
gsmSerial.println("AT+CNMI=2,1,0,0,0"); // Configure GSM to show new SMS on serial
Serial.println("GSM initialization complete.");
// Check if there's an incoming SMS
if (gsmSerial.available()) {
String sms = gsmSerial.readString();
Serial.println("Received SMS:");
Serial.println(sms);
if (sms.indexOf("Location") >= 0) { // Replace "Location" with your keyword
sendLocation();
// Process GPS data
while (gpsSerial.available() > 0) {
gps.encode(gpsSerial.read());
if (gps.location.isUpdated()) {
Serial.print("Latitude: ");
Serial.println(gps.location.lat(), 6);
Serial.print("Longitude: ");
Serial.println(gps.location.lng(), 6);
void sendLocation() {
String recipientNumber = "+01xxxxxxx"; // Replace with the actual recipient number
if (gps.location.isValid()) {
float latitude = gps.location.lat();
float longitude = gps.location.lng();
// Create a Google Maps link
String mapsLink = "https://www.google.com/maps?q=" + String(latitude, 6) + "," + String(longitude, 6);
String message = "Current Location: " + mapsLink;
Serial.println("Sending SMS...");
gsmSerial.println("AT+CMGS=\"" + recipientNumber + "\""); // Set recipient number
gsmSerial.println(message); // Send message
gsmSerial.println((char)26); // ASCII code of CTRL+Z to send SMS
delay(5000);
Serial.println("SMS sent.");
Serial.println("Failed to get GPS location.");
***strong text***
My component now are
1.arduino Uno
2.GSM SIM900A
3.NEO-6M-0-001
4.LM2596
5.Battery 3.7V
Is there any addition component should i add and can you teach me how to get the message on Google maps live location link?
Welcome to the forum
Forget your question in the topic title for now
I can say with some certainty that 2 instances of SoftwareSerial will not work in your project because there is only one receive buffer shared between the two of them
ouh thank u for the reply so how to do it?my pin number is wrong? sorry im the beginner
It does not matter which pins you use for the two instances of SoftwareSerial, it will not work if both can receive data at any time. You can switch between the two instances by using the SoftwareSerial listen() function but I have never seen anyone make that work with anything other than a trivial example sketch
As to what you can do about it, the obvious answer is to use an Arduino with more than one hardware Serial port such as a Mega
ok im done change it to arduino Mega
Just to be clear, when you use the Mega you do not need to use SoftwareSerial, nor should you try
so can i use like this ?AltSoftSerial gpsSerial; // Default RX is pin 8, TX is pin 9 AltSoftSerial gsmSerial; // Default RX is pin 10, TX is pin 11
#include <AltSoftSerial.h>
// Create AltSoftSerial connections
TinyGPSPlus gps;
sendLocation();
// Process GPS data
delay(5000);
Why are you still trying to use software serial in any form? As @UKHeliBob has already pointed out the Mega has multiple hardware serial ports.
TinyGPSPlus gps;
Serial1.begin(9600); // GPS module connected to Serial1 (TX1/RX1)
Serial2.begin(9600); // GSM module connected to Serial2 (TX2/RX2)
Serial2.println("AT+CMGF=1"); // Set SMS text mode
Serial2.println("AT+CNMI=2,1,0,0,0"); // Configure GSM to show new SMS on serial
// Check if there's an incoming SMS from the GSM module
if (Serial2.available()) {
String sms = Serial2.readString();
sendLocation();
// Process GPS data from the GPS module
while (Serial1.available() > 0) {
gps.encode(Serial1.read());
String recipientNumber = "+01xxxx"; // Replace with the actual recipient number
Serial2.println("AT+CMGS=\"" + recipientNumber + "\""); // Set recipient number
Serial2.println(message); // Send message
Serial2.println((char)26); // ASCII code of CTRL+Z to send SMS
delay(5000);
ok like this? serial monitor function but how to receive sms?
i sent the sms to the simcard number but it said that the "sms didnt reach as the phone is switched off" how to solve this problem ?
Have the recipient turn on their 'phone
yes
My reply was a suggestion that the recipient 'phone needs to be turned on, not a question
Which sketch are you running and are you sure that you are using the correct recipient 'phone number ?
