I found this code for this on this website https://sites.google.com/site/openspinmicroscopy/home/sub-systems/sample-rotation
but I don't know how this works. Here is the Code
* This goal of the application is to set the digital output on pins 8-13
* This can be accomplished in three ways. First, a serial command can directly set
* the digital output pattern. Second, a series of patterns can be stored in the
* Arduino and TTLs coming in on pin 2 will then trigger to the consecutive pattern (trigger mode).
* Third, intervals between consecutive patterns can be specified and paterns will be
* generated at these specified time points (timed trigger mode).
* Interface specifications:
* digital pattern specification: single byte, bit 0 corresponds to pin 8,
* bit 1 to pin 9, etc.. Bits 7 and 8 will not be used (and should stay 0).
* Set digital output command: 1p
* Where p is the desired digital pattern. Controller will return 1 to
* indicate succesfull execution.
* Get digital output command: 2
* Controller will return 2p. Where p is the current digital output pattern
* Set Analogue output command: 3xvv
* Where x is the output channel (either 1 or 2), and vv is the output in a
* 12-bit significant number.
* Controller will return 3xvv:
* Get Analogue output: 4
* Set digital patten for triggered mode: 5xd
* Where x is the number of the pattern (currently, 12 patterns can be stored).
* and d is the digital pattern to be stored at that position. Note that x should
* be the real number (i.e., not ASCI encoded)
* Controller will return 5xd
* Set the Number of digital patterns to be used: 6x
* Where x indicates how many digital patterns will be used (currently, up to 12
* patterns maximum). In triggered mode, after reaching this many triggers,
* the controller will re-start the sequence with the first pattern.
* Controller will return 6x
* Skip trigger: 7x
* Where x indicates how many digital change events on the trigger input pin
* will be ignored.
* Controller will respond with 7x
* Start trigger mode: 8
* Controller will return 8 to indicate start of triggered mode
* Stop triggered mode by sending any key (including new commands, that will be
* processed). Trigger mode will stop blanking mode (if it was active)
* Get result of Trigger mode: 9
* Controller will return 9x where x is the number of triggers received during the last
* trigger mode run
* Set time interval for timed trigger mode: 10xtt
* Where x is the number of the interval (currently, 12 intervals can be stored)
* and tt is the interval (in ms) in Arduino unsigned int format.
* Controller will return 10x
* Sets how often the timed pattern will be repeated: 11x
* This value will be used in timed-trigger mode and sets how often the output
* pattern will be repeated.
* Controller will return 11x
* Starts timed trigger mode: 12
* In timed trigger mode, digital patterns as set with function 5 will appear on the
* output pins with intervals (in ms) as set with function 10. After the number of
* patterns set with function 6, the pattern will be repeated for the number of times
* set with function 11. Any input character (which will be processed) will stop
* the pattern generation.
* Controller will retun 12.
* Start blanking Mode: 20
* In blanking mode, zeroes will be written on the output pins when the trigger pin
* is low, when the trigger pin is high, the pattern set with command #1 will be
* applied to the output pins.
* Controller will return 20
* Stop blanking Mode: 21
* Stops blanking mode. Controller returns 21
* Blanking mode trigger direction: 22x
* Sets whether to blank on trigger high or trigger low. x=0: blank on trigger high,
* x=1: blank on trigger low. x=0 is the default
* Controller returns 22
* Get Identification: 30
* Returns (asci!) MM-Ard\r\n
* Get Version: 31
* Returns: version number (as ASCI string) \r\n
* Read digital state of analogue input pins 0-5: 40
* Returns raw value of PINC (two high bits are not used)
* Read analogue state of pint pins 0-5: 41x
* x=0-5. Returns analogue value as a 10-bit number (0-1023)
* Possible extensions:
* Set and Get Mode (low, change, rising, falling) for trigger mode
* Get digital patterm
* Get Number of digital patterns
#define DIR_PIN 2
#define STEP_PIN 3
unsigned int version_ = 2;
// pin on which to receive the trigger (either 2 or 3, changed attachInterrupt accordingly)
int inPin_ = 7;
// pin connected to DIN of TLV5618
int dataPin = 3;
// pin connected to SCLK of TLV5618
int clockPin = 4;
// pin connected to CS of TLV5618
int latchPin = 5;
// pin connected to LDAC
int LDACPin = 6;
const int SEQUENCELENGTH = 12; // this should be good enough for everybody;)
byte triggerPattern_[SEQUENCELENGTH] = {0,0,0,0,0,0,0,0,0,0,0,0};
unsigned int triggerDelay_[SEQUENCELENGTH] = {0,0,0,0,0,0,0,0,0,0,0,0};
int patternLength_ = 0;
byte repeatPattern_ = 0;
volatile int triggerNr_; // total # of triggers in this run (0-based)
volatile int sequenceNr_; // # of trigger in sequence (0-based)
int skipTriggers_ = 0; // # of triggers to skip before starting to generate patterns
byte currentPattern_ = 0;
const unsigned long timeOut_ = 1000;
bool blanking_ = false;
bool blankOnHigh_ = true;
// Higher speeds do not appear to be reliable
Serial.begin(57600);
pinMode(inPin_, INPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(LDACPin, OUTPUT);
pinMode(DIR_PIN, OUTPUT);
pinMode(STEP_PIN, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
// Set analogue pins as input:
DDRC = DDRC & B11000000;
// Turn on build-in pull-up resistors
PORTC = PORTC | B00111111;
if (Serial.available() > 0) {
int inByte = Serial.read();
switch (inByte) {
// Set digital output
case 1 :
if (waitForSerial(timeOut_)) {
currentPattern_ = Serial.read();
// Do not set bits 6 and 7 (not sure if this is needed..)
currentPattern_ = currentPattern_ & B00111111;
float vel=0.25; ///velocity
int mov=0; //steps to move
if (!blanking_){
if(currentPattern_ == 2) {mov=100*8; rotate(mov,vel); delay(500);} // 180º
else if(currentPattern_ == 4) {mov=50*8; rotate(mov,vel); delay(500);} // 90º
else if(currentPattern_ == 6) {mov=25*8; rotate(mov,vel); delay(500);} // 45º
else if(currentPattern_ == 8) {mov=10*8; rotate(mov,vel); delay(500);} // 18º
else if(currentPattern_ == 10) {mov=5*8; rotate(mov,vel); delay(500);} // 9º
else if(currentPattern_ == 12) {mov=1*8; rotate(mov,vel); delay(500);} // 1.8º
else if(currentPattern_ == 40) {mov=1*4; rotate(mov,vel); delay(500);} // 0.9º
else if(currentPattern_ == 42) {mov=1*2; rotate(mov,vel); delay(500);} // 0.45º
else if(currentPattern_ == 44) {mov=1; rotate(mov,vel); delay(500);} // 0.225º
else if(currentPattern_ == 46) {mov=200*8; rotate(mov,vel); delay(500);} // 360º
else if(currentPattern_ == 3) {mov=-100*8; rotate(mov,vel); delay(500);} // 180º
else if(currentPattern_ == 5) {mov=-50*8; rotate(mov,vel); delay(500);} // 90º
else if(currentPattern_ == 7) {mov=-25*8; rotate(mov,vel); delay(500);} // 45º
else if(currentPattern_ == 9) {mov=-10*8; rotate(mov,vel); delay(500);} // 18º
else if(currentPattern_ == 11) {mov=-5*8; rotate(mov,vel); delay(500);} // 9º
else if(currentPattern_ == 13) {mov=-1*8; rotate(mov,vel); delay(500);} // 1.8º
else if(currentPattern_ == 41) {mov=-1*4; rotate(mov,vel); delay(500);} // 0.9º
else if(currentPattern_ == 43) {mov=-1*2; rotate(mov,vel); delay(500);} // 0.45º
else if(currentPattern_ == 45) {mov=-1; rotate(mov,vel); delay(500);} // 0.225º
else if(currentPattern_ == 47) {mov=-200*8; rotate(mov,vel); delay(500);} // 360º
/* //rotate a specific number of degrees
rotateDeg(360, 1);
rotateDeg(-360, .1); //reverse
//rotate a specific number of microsteps (8 microsteps per step)
//a 200 step stepper would take 1600 micro steps for one full revolution
rotate(1600, .5);
rotate(-1600, .25); //reverse
delay(1000); */
else {PORTB = currentPattern_;}
Serial.write( byte(1));
// Get digital output
case 2:
Serial.write( byte(2));
Serial.write( PORTB);
// Set Analogue output (TODO: save for 'Get Analogue output')
case 3:
// Sets the specified digital pattern
case 5:
int patternNumber = Serial.read();
if ( (patternNumber >= 0) && (patternNumber < SEQUENCELENGTH) ) {
triggerPattern_[patternNumber] = Serial.read();
triggerPattern_[patternNumber] = triggerPattern_[patternNumber] & B00111111;
Serial.write( byte(5));
Serial.write( patternNumber);
Serial.write( triggerPattern_[patternNumber]);
Serial.write( "n:");//Serial.print("n:");
// Sets the number of digital patterns that will be used
case 6:
int pL = Serial.read();
if ( (pL >= 0) && (pL <= 12) ) {
patternLength_ = pL;
Serial.write( byte(6));
Serial.write( patternLength_);
// Skip triggers
case 7:
skipTriggers_ = Serial.read();
Serial.write( byte(7));
Serial.write( skipTriggers_);
// starts trigger mode
case 8:
if (patternLength_ > 0) {
sequenceNr_ = 0;
triggerNr_ = -skipTriggers_;
int state = digitalRead(inPin_);
PORTB = B00000000;
Serial.write( byte(8));
while (Serial.available() == 0) {
int tmp = digitalRead(inPin_);
if (tmp != state) {
if (triggerNr_ >=0) {
PORTB = triggerPattern_[sequenceNr_];
sequenceNr_++;
if (sequenceNr_ >= patternLength_)
sequenceNr_ = 0;
triggerNr_++;
state = tmp;
PORTB = B00000000;
// return result from last triggermode
case 9:
Serial.write( byte(9));
Serial.write( triggerNr_);
// Sets time interval for timed trigger mode
// Tricky part is that we are getting an unsigned int as two bytes
case 10:
unsigned int highByte = 0;
unsigned int lowByte = 0;
highByte = Serial.read();
lowByte = Serial.read();
highByte = highByte << 8;
triggerDelay_[patternNumber] = highByte | lowByte;
Serial.write( byte(10));
Serial.write(patternNumber);
// Sets the number of times the patterns is repeated in timed trigger mode
case 11:
repeatPattern_ = Serial.read();
Serial.write( byte(11));
Serial.write( repeatPattern_);
// starts timed trigger mode
case 12:
PORTB = B00000000;
Serial.write( byte(12));
for (byte i = 0; i < repeatPattern_ && (Serial.available() == 0); i++) {
for (int j = 0; j < patternLength_ && (Serial.available() == 0); j++) {
PORTB = triggerPattern_[j];
delay(triggerDelay_[j]);
PORTB = B00000000;
// Blanks output based on TTL input
case 20:
blanking_ = true;
Serial.write( byte(20));
// Stops blanking mode
case 21:
blanking_ = false;
Serial.write( byte(21));
// Sets 'polarity' of input TTL for blanking mode
case 22:
int mode = Serial.read();
if (mode==0)
blankOnHigh_= true;
blankOnHigh_= false;
Serial.write( byte(22));
// Gives identification of the device
case 30:
Serial.println("MM-Ard");
// Returns version string
case 31:
Serial.println(version_);
case 40:
Serial.write( byte(40));
Serial.write( PINC);
case 41:
int pin = Serial.read();
if (pin >= 0 && pin <=5) {
int val = analogRead(pin);
Serial.write( byte(41));
Serial.write( pin);
Serial.write( highByte(val));
Serial.write( lowByte(val));
case 42:
int state = Serial.read();
Serial.write( byte(42));
Serial.write( pin);
if (state == 0) {
digitalWrite(14+pin, LOW);
Serial.write( byte(0));
if (state == 1) {
digitalWrite(14+pin, HIGH);
if (blanking_) {
if (blankOnHigh_) {
if (digitalRead(inPin_) == LOW)
PORTB = 0;
PORTB = 0;
bool waitForSerial(unsigned long timeOut)
unsigned long startTime = millis();
while (Serial.available() == 0 && (millis() - startTime < timeOut) ) {}
return true;
return false;
// Sets analogue output in the TLV5618
// channel is either 0 ('A') or 1 ('B')
// value should be between 0 and 4095 (12 bit max)
// pins should be connected as described above
// This function is called through an interrupt
void triggerMode()
sequenceNr_++;
sequenceNr_ = 0;
triggerNr_++;
void blankNormal()
if (DDRD & B00000100) {
} else
PORTB = 0;
void blankInverted()
PORTB = 0;
void rotate(int steps, float speed){
//rotate a specific number of microsteps (8 microsteps per step) - (negitive for reverse movement)
//speed is any number from .01 -> 1 with 1 being fastest - Slower is stronger
int dir = (steps > 0)? HIGH:LOW;
steps = abs(steps);
digitalWrite(DIR_PIN,dir);
float usDelay = (1/speed) * 70;
for(int i=0; i < steps; i++){
digitalWrite(STEP_PIN, HIGH);
delayMicroseconds(usDelay);
digitalWrite(STEP_PIN, LOW);
void rotateDeg(float deg, float speed){
//rotate a specific number of degrees (negitive for reverse movement)
int dir = (deg > 0)? HIGH:LOW;
int steps = abs(deg)*(1/0.225);
I have to make the code as it will take input of wavelength or steps and move to that position The monochromator i am going to use is Horiba / Spex 1681B ( Horiba / Spex 1681B 0.22m Spectrometer - Price, Specs) it has the maximum step of 500 steps/sec.
