CAN BUS I/O
I'm trying to setup a simple 16ch output canbus
I want to send a Can Message with 16 outputs in it
for example
Bit 1 would be 0001 and that would be the first of 8 bytes in the message.
The receiver arduino would look at the message and depending on what bit was changed to a 1 would turn on that output
so the CAN message would be
0x00, 0, 8,xxxx,xxxx,xxxx,xxxx,
I'm having issues getting it to work
for one not sure how I get each byte to send a binary value. I was think binary to hex.
this is my code so far
Send test
#include <mcp_can.h>
#include <SPI.h>
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 9;
MCP_CAN CAN(SPI_CS_PIN);                                    // Set CS pin
unsigned int bit1 = 0001;
unsigned int bit2 = 0010;
unsigned int bit3 = 0100;
unsigned int bit4 = 1000;
unsigned int bit5 = 1001;
unsigned int bit6 = 1010;
unsigned int bit7 = 1100;
unsigned int bit8 = 1111;
START_INIT:
    if(CAN_OK == CAN.begin(CAN_250KBPS))                   // init can bus : baudrate = 500k
        Serial.println("CAN BUS Shield init ok!");
        Serial.println("CAN BUS Shield init fail");
        Serial.println("Init CAN BUS Shield again");
        delay(100);
        goto START_INIT;
unsigned int onoff1 = bit1;
unsigned int onoff2 = bit2;
unsigned int onoff3 = bit3;
unsigned int onoff4 = bit4;
uint8_t onoff5 = bit5;
uint8_t onoff6 = bit6;
uint8_t onoff7 = bit7;
uint8_t onoff8 = bit8;
unsigned char onoff[8] = {onoff1 , onoff2 , onoff3, onoff4, onoff5, onoff6, onoff7, onoff8};
    // send data:  id = 0x00, standrad frame, data len = 8, stmp: data buf
    CAN.sendMsgBuf(0x0, 0, 8, onoff);
    delay(100);                       // send data per 100ms
Receive Test
 if(CAN_MSGAVAIL == CAN.checkReceive())            // check if data coming
        CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
        unsigned char canId = CAN.getCanId();
Serial.println("-----------------------------");
        Serial.println("get data from ID: ");
        Serial.println(canId);
        for(int i = 0; i<len; i++)    // print the data
            Serial.print(buf[i]);
            Serial.print("\t");
    if(canId == 0x0)
      digitalWrite(16, HIGH);
      digitalWrite(16, LOW);
   delay(100);
} // loop
For the test code I'm just trying to have the led turn on if it see's that canId.
It does see the id and turn on but doesn't turn off once the message is being sent.
I'm really wanting it to read the message and then turn on what ever out it sees a 1 for
I may be going about this all wrong. In the end I'm trying to setup a CAN message that sends binary status of onoff states.
Thanks,
I stopped reading here.
This makes absolutely no sense.
Bit 1 can only be '0' or '1'.
A byte is 8 bits...so 0001 would not even be the first byte...it is the first half-byte or "nibble".
