I have connected an arduino with CAN shield to a CAN bus to read messages from the bus and check the status/value of a particular signal within a message. For example, there are 3 messages on the CAN and each is of 8 bytes. The message IDs are 0X111, 0X222, 0X333 and I want to receive only 0X111 from the bus and then check a specific 2 bit signal within this message (0X111). How can I do that?
0X111 is 8X8 matix:
bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0
0
1 X X I want to check the 5th and 6th bits of the byte[1]
2
3
4
5
6
7
8
if (mcp2515.readMessage(&canMsg) == 0X111)
here I want to check the status of the 5th & 6th bits within the 1st byte of 0X111 but don't
know about the instructions/code.
Thanks for your prompt feedback. Let me know if my understanding about bitRead is correct or not.
1st- select the byte position (1st in my case) of the message 0X311 by canMsg.data[1]
2nd- then extract the bits 5 and 6 through 2 separate bitRead commands as shown below:
int a,b;
a=bitRead(canMsg.data[1],5);
b=bitRead(canMsg.data[1],6);
if( (a==0 && b==1))
Serial.print("test case passed");
Serial.print("test case failed");
For your information, the signal occupying the bits 5 and 6 of byte 1 indicates the status of a device:
6th bit 5th bit
0 0 Invalid
0 1 OFF
1 0 ON
1 1 Reserved
I want to test the condition to check if the device is ON or not.
int a,b;
if( (a==0 && b==1))
6th bit 5th bit
0 0 Invalid
0 1 OFF
1 0 ON
1 1 Reserved
I can't quite see how this is a question for Interfacing w/ Software on the Comouter. It seems a more general programming question and hence your topic has beem moved.
I am not able to receive 0X111 this message with the following command:
Since LED is not turning on, it indicates the condition if(mcp2515.readMessage(&canMsg)==0X111) is failing i.e. message is not received but I am confident that 0X111 is there in the CAN bus
#include<SPI.h>
#include<mcp2515.h>
#include<can.h>
struct can_frame canMsg; #define CS 10;
int LED=3;
pinMode(LED,OUTPUT);
while(!Serial);
mcp2515.reset();
mcp2515.setBitrate(CAN_500KBPS, MCP_8MHZ);
mcp2515.setNormalMode();
void loop
digitalWrite(LED,HIGH);
int bit5, bit6;
bit5=bitRead(canMsg.data[1],5);
bit6=bitRead(canMsg.data[1],6);
if(bit5==0 && bit6==1)
Serial.print("Module is ON");
Serial.print("Module status update failed");
From the example code for that library... it looks like you are not interpreting the response from readMessage correctly. It returns an error response, and if ok you then need to look at canMsg.can_id, canMsg.can_dlc and canMsg.data[].
if (mcp2515.readMessage(&canMsg) == MCP2515::ERROR_OK) {
Serial.print(canMsg.can_id, HEX); // print ID
Serial.print(" ");
Serial.print(canMsg.can_dlc, HEX); // print DLC
Serial.print(" ");
for (int i = 0; i<canMsg.can_dlc; i++) { // print the data
Serial.print(canMsg.data[i],HEX);
Serial.print(" ");
I'm not a CAN guy, but I fail to see how you can get 0x111 in a byte - am I misinterpreting, or is the OP not quite on message? 0b111, sure. 0X111 (usually written 0x111) implies at least a 9-bit value.
so I modified my code but it is still not working.
void loop
if(canMsg.can_id == 0X111) /0X111 is the message id
do this;
