I've been trying to sniff messages from my 2011 Kia Picanto using an Arduino Uno and an MCP2515 can bus module. I've been trying for the past few days but could not read out any messages. Last year I did a similar project with a Truck and it worked perfectly. I'm really desperate at this point because this is a project for uni. Pls help. Below is a picture of the setup and the code.
#include <mcp_can.h>
#include <SPI.h>
const int SPI_CS_PIN = 10; // Chip Select pin for MCP2515
MCP_CAN CAN(SPI_CS_PIN); // Set CS pin for MCP_CAN instance
while (!Serial); // Wait for serial port to connect - needed for Leonardo only
if (CAN.begin(MCP_ANY, CAN_250KBPS, MCP_8MHZ) == CAN_OK) {
Serial.println("MCP2515 Initialized Successfully!");
Serial.println("Error Initializing MCP2515!");
while (1);
unsigned long canId = 0; // Variable to store CAN ID
unsigned char len = 0; // Variable to store length of the CAN message
unsigned char buf[8]; // Data buffer to store received data
if (CAN_MSGAVAIL == CAN.checkReceive()) {
CAN.readMsgBuf(&canId, &len, buf); // Read the data
Serial.print("Message ID: ");
Serial.print(canId, HEX);
Serial.print(" Length: ");
Serial.println(len);
for (int i = 0; i < len; i++) { // Print each byte of the data
Serial.print(buf[i], HEX);
Serial.print(" ");
Are you following the OBDII protocol or just listing. Many vehicles do not connect the OBDII port to the internal CAN bus but pass it through a gateway. Th reason is this keeps many of the packets private and prevents external interference. Placing improper packets on the CAN bus can damage the vehicle.
There's activity on both pins. I reconfigured my arduino to read out the high and low pins over teh analog inputs and they very clearly showed dominant (1,5;3,5) and recessive bits (2,5;2,5). Would sending a direct PID query to the car solve the issue? I'm not receiving anything at all at this point.
Here's my idea. Let me know whether I understood you correctly:
#include <SPI.h>
const int SPI_CS_PIN = 10; // Set CS pin
if (CAN.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK) {
while (1); // Halt if initialization fails
// PID request for engine RPM (0x0C)
byte pidRequest[] = {0x02, 0x01, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00};
// Standard OBD-II PID request on PID 0x7DF (the diagnostic PID)
CAN.sendMsgBuf(0x7DF, 0, 8, pidRequest);
delay(1000); // Wait a second
CAN.readMsgBuf(&len, buf); // Read data: len = data length, buf = data byte(s)
Serial.println("Received response:");
Serial.print(" ");
Are you operating at the correct baud rate, I have no idea. The library you used has both a send and a receive modules, set up another CAN node and see if they can talk to each other first, if not they will not talk to the car. Try using mills in place of delay which is blocking.
